App for playing videos from USB.
Hello,  I am looking for an app through which I can play videos on USB because inbuilt media players do not support all formats. And in some videos I'm facing frame drops or lagging.
I use the standard Media Player on my LG Nanocell TV
It plays all the modern media type, MKV and MP4 perfectly smoothly
If a file will not play I run it through  Format Factory on my PC to convert to MKV with 265 compression
No visible loss of quality but file size reductions are beneficial as I have a large archive
As for the frame drops and lagging, I suggest you look at the cable you are using to connect the USB
and try a different USB.  The cheap ones are not always good quality
I run my videos from a USB hdd
    • By Andreas Boyatzoglou
      Model: OLED55BX3LB
      Viewing videos from
      link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site  cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
    • By Nihar Ranjan Dash
      The international content on JioCinema and Hotstar apps are not playing. No issues with Indian content in Hindi or other regional languages. But English, Korean, and Japanese content are not playing. Specifically, I want to play Disney content on Hotstar and HBO content on JioCinema App.
      I tried resetting all configurations and reinstalling the applications and re-logging into the apps. Still, the issue persists. I tried switching off the TV and tried pressing the power button for complete discharge and rebooting my router, but the same issue persists.
      **I found a workaround though, changing the wifi network or using a mobile hotspot on TV and then all content plays well even if I revert to my primary Airtel wifi, It still plays. but the next day the same issue continues.
      It's an overhead to switch the wifi every time I want to watch Hollywood titles. Certainly, it's not the experience I want with a TV of a hefty price tag. No other devices (Mac, ios, android, windows, Android TV) have this problem. Also, it's not the wifi issue, as I can watch the same titles on other devices. The LG TV also doesn't have the capability to remember a few WiFi networks to ease this workaround of switching networks.
      Alas, Nobody informed me about this issue earlier while making the purchase. Now such pricey TVs shouldn't have these issues at all. Kindly let me know If there is a permanent fix for this issue.
    • By keshav iyer
    • By alfie
    • By Low Grade
      hi,
