App Icon Cannot Be Moved
By starwoodtech
By Peter Steinmeijer
Is my TV too old ?
By Stephen Davies
By williemyers
hi all,
for a couple of years now, I've enjoyed AirPlay between my mid-2012 MacBook Pro and my LG Smart TV. But last week, I had to do a Migriation Asst./Time Machine re-install of the system drive on my MacBook Pro/Mojave. Result is that I can no longer get a connection with my LG TV. Two things:
When attempting to AirPlay connect, I now get a Mac window asking for a PIN code. Then , the LG goes black and gives me a 4-digit AirPlay code, I enter it in to the Mac, but it reports, "could not connect to LG TV" etc. 2. I've put an AirPlay icon in the menu bar, but when I click on it, I see a greyed-out "AirPlay:" that constantly switches back and forth between "AirPlay: Looking for TV..." and "AirPlay: Off"
All help/thoughts appreciated!
By Jimout
I am getting a "cannot download files" when I try and download a FirePro file.
I was able to download before.
Is there a way around or fix.
Joe C
