PreCentral: Adjust Gesture Detection Method (LunaCE)
By Low Grade
many thanks in advance😃
By dolbnya
By Siva Shankar reddy
We are using WebOs library v1.2.4 and we are using the service: com.webos.notification, and we are trying to use the "enable" method. it is returning below error.
ERROR :
{"returnValue": false, "errorCode": -1, "errorText": "Denied method call \"enable\" for category \"/\""}
CODE SNIPPET:
webOS.service.request( 'luna://com.webos.notification', {
method: 'enable',
onSuccess: function( inResponse ){
onFailure: function( inError ){
To Give Corporate Customers the Level of Protection they Demand, Company is
Applying Reliable Anti-Eavesdropping System to Latest Digital Signage Solutions
SEOUL, Aug. 11, 2022 — LG Electronics (LG) is introducing an innovative eavesdropping detection solution for its commercial signage products. Going forward, the cutting-edge security system will be applied to the company’s flagship models, including LG LED All-in-One, LG LED Bloc and LG MAGNIT, as well as select video walls and UHD signage products supporting webOS 4.1.
As demand for commercial signage products expands across multiple industries, so does the need for related technologies that serve the needs of companies operating in different sectors. Although counter-surveillance is important in every sector, some entities such as corporates, government agencies, national institutions and the military prioritize confidentiality and the protection of personal information. LG, in partnership with high-tech security technology provider
link hidden, please login to view, has addressed this growing need by installing a dedicated app that runs with GITSN’s eavesdropping detection terminal in LG’s smart signage platform, webOS. The new eavesdropping detection function displays a warning icon on screen in real time as soon as it detects any abnormal signal. The system utilizes simple icons to keep attendees updated on just how secure they are at all times. Moreover, LG’s webOS-based detection function, which can cover multiple conference/control rooms at once, analyzes every inch of a potential risk fast and accurately to alert those in charge immediately.
“LG’s newest solution detects various potential, unexpected risks and reports it immediately, while also bringing the company’s security management up to date,” said Paik Ki-mun, senior vice president and head of the Information Display business unit of LG Electronics Business Solutions Company. “LG will continue to introduce the high-definition display solutions that not only express the most vivid colors and clear images to date, but also let consumers feel safe while they use them.”
The latest signage solution will be available in the third quarter of 2022, starting with key markets in Middle East and Asia, with other markets to follow.
By peppeve
Is possible to have the correct code to set in AREA CODE from the ezadjust menu for my tv? I have an imported EU 60lb730v my actual code is 3122 but i need ITALIAN AREA CODE for set on the MHP function. Thank's
