PreCentral: WebOS Ports running wallpaper contest, make your photo the Ports default
If you've done any tinkering around with the
of , you've likely noticed the wallpaper they've been making use of. It's an image the sun rising over a foggy and rocky coastline. It's coloful. It's visually pleasing. It's nice. .
The fine folks at WebOS Ports have decided it's time to replace their choice for the wallpaper, and they want you to submit your images for consideration. Officially the contest is to include the wallpaper on the , though it's possible the wallpaper could find its way onto other WebOS Ports projects.
They're looking for images that are at least 1280px x 1280px (remember, Open webOS can rotate any which way), and of course it has to an image that isn't protected under copyright - i.e. something you've personally produced - and should not include the recognizable faces of people. Apart from that, it's a free-for-all.
Instructions on how to submit your image are at the source link below (time to learn how to IRC and how to Wiki), and submissions are open through the end of January. So go ahead, dig up that awesome image of yours and submit it. You never know, it might end up installing along with every Galaxy Nexus Open webOS port.
a2t.imgjcO6MIiA8Hc
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By anna groove
    • By Jaswinder Sandhu
    • By tarakdave
