0822-46435524 . Layanan ini tersedia 24 jam, jadi kamu bisa menghubungi mereka kapan saja, baik melalui telepon rumah maupun handphone
0822-4643-5524. Layanan ini tersedia 24 jam, jadi kamu bisa menghubungi mereka kapan saja, baik melalui telepon rumah maupun handphone
      for AI Data Centers
      In a strategic move to bolster its presence in Indonesia, LG is accelerating the capabilities of its Research and Development (R&D) Center in the country by investing in its most valuable asset – its people.
      Last year,
      link hidden, please login to view officially opened its world-class R&D facility, aiming to elevate the company’s operational capabilities and further its mission of delivering quality products to more consumers worldwide. The 40,000-square-meter R&D center in Cibitung is set to become a pivotal hub for LG’s expansion into new global markets. This facility allows LG to implement a one-stop operation in Indonesia, integrating its supply chain processes into a seamless workflow that encompasses development, production, sales, marketing and customer service. This makes LG Indonesia the first LG subsidiary in the world capable of performing these roles simultaneously.
      “Our R&D Center in the heart of Indonesia reinforces our unwavering dedication to serving Indonesia with the highest quality products, bringing up highly competitive manpower with creating jobs, transferring knowledge and making innovations,” said Lee So-yeoun, president of the LG R&D Center in Indonesia. “We anticipate our Indonesia R&D Center to continue positively impacting not only the company but also Indonesia’s broader society.”
      This state-of-the-art facility will not only serve as a testing ground for LG’s latest innovations but also support the development of new TVs for the global market.
      The center conducts rigorous tests on products to assess their resistance to moisture, heat and vibration as well as the packaging’s ability to protect items from significant drops. These tests are carried out to verify the durability of LG TVs throughout the product life cycle, from shipment to actual use.
      Beyond technological development, LG Indonesia seeks to empower local human resources through the new facility. As part of this initiative, LG Indonesia sent 100 local workers to South Korea for a training program to equip them with the necessary knowledge and skills. A highly competent local team leads the facility’s technical and development quality assurance departments, and LG has employed approximately 400 people to run it, with plans to recruit more over the coming years.
      To further improve its human resources, LG’s Indonesia R&D Center is exploring scholarship programs, internships, project sponsorships and partnerships with prominent local educational institutions. This initiative aims to strengthen the industry-academia relationship while creating broader opportunities for Indonesia’s talented youth. This will almost certainly foster greater innovation, leading to new products designed for the global market.
      The Indonesia R&D Center’s high operational standards have earned it three ISO certifications for SHEE (Safety, Health, Environment and Energy): ISO 14001 (Environmental Management), ISO 45001 (Occupational Health and Safety) and ISO 50001 (Energy Management), emphasizing its dedication to safe, eco-friendly operations.
      With the implementation of an advanced Building Management System (BMS), LG’s Indonesia R&D Center ensures environmental sustainability and energy efficiency by monitoring and controlling the air conditioning, ventilation, water systems, fire alarms and power.
      Beyond enhancing operational efficiency, the R&D Center aims to help the company comply with national standards by adapting its products to better serve the local market, such as acquiring the Indonesian National Standard (SNI) certification. Among its most valuable contributions so far, the facility helped develop the LG OLED G4, the latest OLED TV which uses 60 percent less plastic than conventional televisions and recently received the Eco-friendly Certification for the fourth consecutive year.
      Looking ahead, LG’s Indonesia R&D Center will continue to promote sustainability through key ESG initiatives organized under the “LG LOVES Indonesia” program. With a focus on the environment, education, community welfare and child development, the company has already initiated several projects in Indonesia, including “LG Loves Green,” “LG Loves School,” “LG Loves and Cares” and “LG Loves Children.”
      Keep an eye on the to see how else the company is putting its Life’s Good motto into action while striving to make meaningful contributions to local communities.
      Contributed by LG Indonesia
      Company’s Premium Gaming Monitors Deliver the Image Quality and
      Responsiveness That Professional Gamers Demand
      SEOUL, Aug. 21, 2024 — LG Electronics (LG) is set to showcase its industry-leading UltraGear gaming monitors at two of Europe’s biggest gaming events this summer: Gamescom 2024 and the League of Legends EMEA Championship (LEC 2024). The company will also be hosting LG Gaming Weeks, a promotional event offering customers in several European countries special discounts on LG UltraGear gaming monitors, and the chance to receive exclusive gifts.
      Gamescom 2024
      LG UltraGear will be operating a brand experience booth at Gamescom 2024, Europe’s largest video game tradeshow, taking place in Cologne, Germany, from August 21 to 25. Attracting around 370,000 participants annually, Gamescom is one of the most significant events on the gaming industry calendar, with game developers and hardware manufacturers from around the world unveil their latest offerings.
      Visitors to LG UltraGear’s booth will have the opportunity to experience the unmatched immersion delivered by the brand’s stunning OLED gaming monitors. Available in screen sizes of 45-, 39-, 34-, 32- and 27-inches, LG UltraGear OLED gaming monitors feature cutting edge Micro Lens Array Plus (MLA+) technology, are VESA DisplayHDR True Black 400-certified, and boast a peak brightness of 1300 nits. Notably, the 32-inch LG UltraGear OLED gaming monitor (model 32GS95UE) is the world’s first VESA-certified dual-mode display, allowing users to switch seamlessly between 4K UHD 240Hz and FHD 480Hz.
      LEC 2024
      LG UltraGear gaming monitors have also been named the Official Gaming Monitor for the LEC 2024 summer season. At the tournament’s fiercely-contested final rounds in Munich, Germany (August 31 to September 1), the top-ranked teams will be playing for victory using LG UltraGear gaming monitors.
      Throughout the LEC 2024 finals, LG’s UltraGear gaming monitors will be on show at a pop-up operated by Riot Games, the developer of League of Legends. Located on Odeonsplatz, in the heart of downtown Munich, the pop-up will give visitors the chance to play some of Riot Games’ latest titles on LG’s premium gaming displays. These include the stellar 27-inch LG UltraGear OLED gaming monitor (model 27GS95QE), which provides smooth, responsive gameplay with its 240Hz refresh rate and 0.03ms Gray-to-Gray response time. Gaming fans and curious passersby can drop by the pop-up to see first-hand why LG UltraGear is the preferred choice of many of the world’s top gamers.
      LG Gaming Weeks
      Starting in the third week of August, LG Gaming Weeks will present exclusive deals and gifts along with special discounts on UltraGear products that will have gamers from across Europe heading to LG.com. For more information on LG Gaming Weeks, including activity schedules and participating countries, visit link hidden, please login to view.
      “We look forward to connecting with Europe’s gaming community through special encounters at these large-scale offline activities of Gamescom 2024 and LEC 2024, as well as LG Gaming Weeks,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “Through both online and offline events, the LG UltraGear brand will continue to raise its profile by showcasing its impressive OLED gaming monitors at major gaming industry events, and by supporting premier esports tournaments with the best ‘Gear’ around.”
      Leader in Mobility Sector Innovation, Company Exhibits Its Cutting-edge Technologies,
      Provides Insights into Evolution of Software-defined Vehicle at EVS37
      SEOUL, April 23, 2024 — LG Electronics (LG), a respected mobility sector innovator, is participating in the 37th Electric Vehicle Symposium & Exhibition (EVS) at COEX in Seoul, South Korea, from April 23–26. Hosted by the World Electric Vehicle Association (WEVA), EVS has a proud 55-year history and continues to attract top manufacturers, academics and thought leaders from around the globe. At EVS37, themed ‘Electric Waves to Future Mobility,’ LG will showcase its latest electric vehicle (EV) technologies and solutions, including batteries, charging systems and EV components.
      This year’s event will play host to more than 600 booths, with an anticipated attendance of more than 1,500 EV experts and approximately 250 companies. LG Electronics, in conjunction with its sister companies LG Energy Solution, LG Innotek and LG Display, is presenting an array of cutting-edge technologies across key areas of innovation. These range from core EV parts and systems to safe and efficient batteries and chargers. With its diverse portfolio of interrelated and complementary solutions, LG aims to play a significant role in driving the future of mobility.
      Visitors to LG’s booth at EVS37 will have the opportunity to see the company’s premium in-vehicle infotainment (IVI) system. Employing plastic-OLED (P-OLED) display technology, LG’s system seamlessly unites three displays – an instrument panel, center information display (CID) and co-driver display (CDD) – to create a futuristic and elegantly curved panoramic screen. The much-in-demand system, which also incorporates LG’s exclusive curved glass molding, surface treatment and display bonding technologies, can already be found in a premium EV model from one of world’s top automakers.
      LG is also introducing its Automotive Content Platform (ACP) powered by webOS. Designed to elevate the in-vehicle experience, the new platform enables front and backseat passengers to enjoy high-quality video, game and music content while travelling to their destination. Based on the acclaimed webOS platform for LG Smart TV and tailored for in-vehicle use, the ACP powered by webOS offers easy access to a variety of popular OTT apps as well as convenient control and personalized content recommendations. Launched at the end of last year, the LG ACP was initially integrated into Hyundai Motor and Kia’s new Genesis GV80 and GV80 Coupe.
      LG Magna e-Powertrain, a joint venture between LG and Magna, is showcasing its innovative products to the public for the first time at EVS37. Among its offerings are an 800V high-speed hairpin motor capable of producing a 250kW output, an 800V SiC inverter that controls motor with electric energy from the battery and an 800V IPGM drive system integrating a motor, inverter and gearbox.
      As part of the lecture and discussion series taking place at EVS37, LG will present its insights into the challenges of realizing the software-defined vehicle (SDV) – and introduce its technological solutions for overcoming them. Among the scheduled speakers are research fellows from the R&D laboratory at the LG Vehicle component Solutions Company Hong Hyun-taek, Park Young-kyung and software business leader Lee Jun-nyung. Additionally, LG’s R&D experts will demonstrate how the company is developing vehicle-interior sensing technology that will enhance the overall SDV user experience.
      “A recognized leader in advanced vehicle components, LG is excited to unveil its flagship solutions to the public, and share its considerable insight at EVS in Seoul,” said Lee Sang-yong, senior vice president of the R&D laboratory at LG Vehicle component Solutions Company. “Through our cutting-edge technologies, and via strategic collaboration with affiliates and industry partners, we will continue to meet the needs and exceed the expectations of OEMs and end-users.”
      A TÜV Rheinland Appointed Laboratory, Company’s Center Now Able
      to Evaluate Functional Safety of Home Appliance Software
      SEOUL, July 4, 2023 — LG Electronics’ (LG) Software Center has been officially designated a TÜV Rheinland Appointed Laboratory for the purpose of evaluating the functional safety of home appliance software. LG is the first company to have its dedicated software testing facility receive this particular accreditation from TÜV Rheinland, a global leader in testing, inspection and certification services.
      Using tests conducted in accordance with relevant international standards (IEC 60730-1, IEC 60335-1), LG can evaluate the architecture of software applied to its smart home appliances to determine if functional safety requirements have been met. This will help the company to reduce the length of time needed to provide its customers with safe, high-quality products.
      Additionally, LG expects that the accreditation for software testing will further strengthen the competitiveness of its home appliance business, enhancing the trust that customers have in the reliability and overall quality of its advanced household solutions.
      LG continues to advance its business portfolio by expanding its software capabilities across all business areas. In June 2022, the Software Center was designated a TÜV Rheinland Appointed Laboratory, becoming a credible provider of automotive software functional safety evaluations. Prior to that, the center earned accreditation from the Korea Laboratory Accreditation Scheme (KOLAS) to assess autonomous vehicle software and measure the quality of electric and electronic products.
      “We will continue to pursue a variety of activities and initiatives to enhance software quality and boost public confidence, which will ultimately help strengthen the software competitiveness of LG’s products and services,” said Park In-sung, head of the Software Center at LG Electronics.
