PreCentral: Open webOS Project brings back the VirtualBox emulator
Open webOS Hero
The end of another month brings yet another update from the Open webOS Blog giving us all a heads up on the most recent achievements related to
. This month the gang dropped quite a bit of interesting information, probably the biggest of which was the revival of the emulator.
Back when webOS was shiny and new, the emulator was an useful tool for developers to test device-specific features if they didn't have access to the appropriate hardware. As you can imagine, this is very important as developers want their end product to work as intended on all the devices it is available for. Since Open webOS stands to be ported to multiple devices from various manufacturers with all types of hardware configurations, the return of the Virtualbox emulator will likely prove to be invaluable.
Next up is an achievement that is admittedly a bit over our heads: an upgrade to Yocto 1.3. What is Yocto? provides open source back-end tools so developers can create their own custom Linux distributions, and that's for any hardware architecture. How exactly developers will take advantage of Yocto integration in Open webOS is an open question, but that's kind of the point. Couple with thinks like the integration of the and , Open webOS is looking at a wide array of potential hardware platforms on which to play.
Last, but certainly not least, both nodejs and Enyo are getting upgrades in the coming month. The platform is currently getting a small upgrade to 0.8.18 and should be hitting available in its GitHub repo in "the coming days". In the meantime, the team is working feverishly on the 2.2 update which will add both BlackBerry 10 and Windows 8 support.
Yes, folks, Open webOS is still alive and kicking, and the team at HP isn't resting on their laurels now that they've the . Progress is , and while it might , remember that all good things do.
a2t.img_RxgXyynh38
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
    • By tarakdave
    • By AtWitsEnd696
