This tip is only for HP TouchPads running webOS 3.0.5 and LunaCE 4.9.5 or higher
Adjust card view zoom level (LunaCE)Although the size of the screen on the TouchPad is much larger than that of any webOS phone, the size of the apps that are visible in the
and that are shown in  are no different. This is not exactly an efficient use of screen real estate that should allow you to see more of the apps that are available to you. With the released of the Open Source "" for the HP TouchPad (not to be confused with ), the group at was able to give you more control over how the cards and stacks appear on the screen as part (pronounced "lunacy"), available in . Note that LunaCE is currently in beta so you will need to go through the process to set-up the beta feeds in Preware, which can be found at testing.preware.org. In addition, you will need to have installed on your TouchPad to toggle this new feature.
Just as you can adjust the amount to view more of the apps within a stack, LunaCE also gives you the ability to adjust the zoom level of the cards and stacks on the screen.  Once you go into the "Luna" section of Tweaks and toggle "Card Zoom Gestures" to YES in the "GESTURES" section, you can then perform a two-fingered in or out gesture when in Card View to adjust that zoom level. You can keep the zoom to a level where you only see a sliver of the adjacent stacks to the current one, or zoom out to be able to view up to 5 stacks at once in landscape.
The one thing to note is that if you also have the "Stack spread gestures" toggle also set to YES, any time you pinch-in or -out to zoom on a stack with more than one card will prioritize the stack spread gesture and not the zoom amount. You will need to swipe over to a stack with only a single card first and then perform the zoom gesture.
a2t.imgS6TlddTTeKI
    • By Andreas Boyatzoglou
      Model: OLED55BX3LB
      Viewing videos from
      link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site  cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
    • By Janet Rich
      On the LG C4, is there a screen zoom in/zoom out option. This isn’t an aspect ratio question.
    • By Low Grade
      many thanks in advance😃
    • By Fricassee
    • By Maria D
      How to change view from 16:9 in movies to fit full screen
      LG QLED B22
