    • By DA
      Can someone inform me as to when (what generation) they removed the smart zoom feature from their TV's? I want to purchase a new OLED TV but I noticed their smart zoom feature was missing from their remote control. I have a 2016 LG TV that still has it and I use it all the time.
    • By ecallaghan
      I have a 65UJ630V Smart TV and I have attached a Logitech MeetUp 4K camera attached via USB. Is there any way to get Zoom/Skype/Facetime working? The TV has also connected to it an Apple TV so I can cast to it using Airplay but cant work out how to have the Logitech camera do the video rather than the computer on the other side of the room....
      I have looked in the store but no apps seem to do web conferencing....
      Thanks in advance,
    • By PewDieFan no1
      Good morning sir
      Due to the pandemic COVID-19 all the educational institutions , offices started using zoom for video conferencing. So if you introduce zoom in every LG smart TV we can confernce
      This tip is only for HP TouchPads running webOS 3.0.5 and LunaCE 4.9.5 or higher
      Although the size of the screen on the TouchPad is much larger than that of any webOS phone, the size of the apps that are visible in the
      link hidden, please login to view and that are shown in  are no different. This is not exactly an efficient use of screen real estate that should allow you to see more of the apps that are available to you. With the released of the Open Source "" for the HP TouchPad (not to be confused with ), the group at was able to give you more control over how the cards and stacks appear on the screen as part (pronounced "lunacy"), available in . Note that LunaCE is currently in beta so you will need to go through the process to set-up the beta feeds in Preware, which can be found at testing.preware.org. In addition, you will need to have installed on your TouchPad to toggle this new feature. Just as you can adjust the amount to view more of the apps within a stack, LunaCE also gives you the ability to adjust the zoom level of the cards and stacks on the screen.  Once you go into the "Luna" section of Tweaks and toggle "Card Zoom Gestures" to YES in the "GESTURES" section, you can then perform a two-fingered in or out gesture when in Card View to adjust that zoom level. You can keep the zoom to a level where you only see a sliver of the adjacent stacks to the current one, or zoom out to be able to view up to 5 stacks at once in landscape.
      The one thing to note is that if you also have the "Stack spread gestures" toggle also set to YES, any time you pinch-in or -out to zoom on a stack with more than one card will prioritize the stack spread gesture and not the zoom amount. You will need to swipe over to a stack with only a single card first and then perform the zoom gesture.
