Having problems switching between my BT headphones and HMDI ARC soundbar, please help!
By hollean
By Pranay Mokida
By Fredrik Andersson
By janisad
I have an LG 32LJ610V TV.
By Evgeny Dubnov
I intend to buy LG TV 43UK6300Y.
So question: if this TV require the Bluetooth headphones which must support LG sound sync (wireless) function.
If yes, could you send the list of acceptable Bluetooth headphones.
Thank you,
Evgeny
John Nguyen
