Who Bought a Fire Sale HP Touchpad?
Did you buy a Firesale Touchpad?
7 members have voted
  1. 1. Did you buy a Firesale Touchpad?
    • Yes, bought a 16GB
    • Yes, bought a 32GB
      3
    • Yes, bought a 64GB
    • No, missed it
    • Wasn't interested
Thankfully, I was able to get one myself, but it took a few tries and ordering it on the HP Business site. By the time I checked all the retailer, they were gone! Snagged a 16GB for $99! I hope you grabbed one also... :D
I purchased a 16GB from the HP Business site on Saturday. Received an order confirmation, now waiting for shipment.
-- Sent from my Palm Pixi using
  • 2 weeks later...
  • 3 years later...
  • 2 weeks later...
I still use my TouchPad daily
Sent from my SGS3 running Cyanogenmod using Xparent BlueTapatalk
Are you using the Android computability layer? OpenMobile
  • 4 weeks later...
  • 2 years later...
  • 5 months later...
8 hours ago, joshua764 said:
I still use touchpad with Android 7.1.1 and Webos, use pre3 palm. some beauties
Enviado desde mi XT1635-02 mediante Tapatalk
I haven't used mine in a while.
  • 3 weeks later...
  • 1 month later...
In Webos nation there is a new web browser for touchpad that gave new life to the touchpad. I recommend it a lot
  • 1 month later...
I have an old one. I like them.
Sent from my SM-N950U using Tapatalk
  • 5 weeks later...
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By Rosie
      Fire TV upgraded and since then I'm unable to use my remote. I have to use the button below TV and have no freeview. Unable to get to settings to tune TV. Grateful for any advice
    • By karen852
      Hello
      I bought my TV this year in China and I've moved to HK where I can access Netflix & Youtube etc etc, however, I'm unable to change the region settings on my TV as it only allows me to select China under the country list. Is there anyway that I can update the OS manually in order to region switch as the China apps are very limited..
      Thankss
    • By pivotCE
      webOS friend and LuneOS project aficionado, , recently embarked on an unlocking adventure.  His HP TouchPad 4G gave up the ghost and passed away quietly.  So he did what anyone would do and got a new one!  That’s what you’d do if your TouchPad died too, right?
      His TouchPad was special though.  In fact, you probably read his article right here on pivotCE about with an unlocked Sierra 7710 card in it.
      Why not just crack open the new one and pop in the 7710 and throw away that crappy “3.5G” Ericcson card?  Well, the TouchPad pretty much breaks when you open it.  The little clips that keep the back connected weren’t designed to be opened once engaged.
      After Herrie contacted, paid for, and was reimbursed by several unlocking services over the course of about a month he finally stumbled upon which was able to get him an unlock code.  The catch?  It took 2 weeks but it only cost him about $10.50 USD.  Not bad!
      Need your TouchPad 4G unlocked?  Head over to www.unlockfusion.com and I’m certain they can help you.  Or crack yours open and pop in a Sierra 7710 (EU) or a Sierra 7700 (NA).
      #webOSforever
      Related posts:
