LG 50UT91006LA TV Recording
By StefanosBand
By Kev999
I can only get the Reminder facility to work on live TV in the lower channels like 1, 2, 3 etc, but rejects attempts to use with the HD channels at 101, 102 etc. Is this normal?
By Nooneuno
Our tv always needs to have the recording volume reset... the problem seems to be that the formatted disk has a small boot partition, about 150 mb, plus a 4 GB "main" volume, and the recording app "sees' the boot partition, and won't "hold" the setting for the main volume...
By Ron Williams
I am unable to set a reminder or to set recording of any BBC1 programs on my oled 55a26la tv via Freeview .Anyone else experiencing this fault ?
is there a fix for this ?
By Hblone
Hallo, I bought a 55un74006LB smart tv in Italy. It seems not to have usb recording capabilities, according to the information on the italian website, but the UK site declare it has. I think it's the same product with the same functions, so how can I turn the live tv and usb recording on? I think I found the options in the service menu but I cannot change the values. Any suggestion?
