PreCentral: Append TapNote documents with Just Type Quick Actions
By Stephen Davies
By Deniss
After last 13.30.61 update my iptv apps plays just channels for 30 seconds and the pauses. I have used ss iptv app and smart iptv. On my Samsung TV all works fine using the same apps
By Clifford Walker
Upto a few weeks back had no issues but am unable to watch bbc weather page videos?
By Cedric
Since my TV updated to the last WebOS firmware 05.20.08, quick access key (Long Press 1 for HDMI1, Long press 2 for HDMI2) are reset each time i shutdown the TV, and i have to set them after each reboot...
I tried to restore the factory default settings on the TV to see if there is any change, but sadly this didn't fixed my problem.
Any idea please ?
By pattox
It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose the + add item. If you want to add a "shortcut" to an item that is not on the list then how can that be done. Is it possible to edit the list presented?
Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings, there nothing on the list of options presented to allow this.
