A Technological Journey Through Affectionate Intelligence at CES 2025
for AI Data Centers
The Company Achieves Record-High First-Quarter Revenue
Surpassing KRW 22 Trillion
SEOUL, Apr. 7, 2025 — LG Electronics Inc. (LG) today announced its preliminary earnings results for the first-quarter of 2025, reporting a consolidated revenue of KRW 22.7 trillion and operating profit of KRW 1.3 trillion.
This marks the first time LG’s first-quarter revenue has exceeded KRW 22 trillion. Despite ongoing macroeconomic challenges, including a global economic slowdown, the company’s focus on “qualitative growth” businesses played a key role.
Especially in B2B sectors, the Eco Solution (ES) business has been the primary driver of growth in both revenue and profitability. Other areas—such as subscription services, webOS-based advertising and content, and direct-to-consumer (D2C) sales—also contributed to the company’s record-breaking results.
Operating profit exceeded KRW 1 trillion for the sixth consecutive year, continuing to reflect a stable profit structure. Increased revenue from high-margin areas created a strong operating leverage effect, helping to sustain a stable profit structure. Additional drivers of profitability included efficient resource allocation, normalization of raw material and logistics costs, and enhanced agility in global production operations.
In the home appliance solution business, LG’s premium products maintained strong leadership in the global market. The built-in appliance business – a B2B segment – alongside key component sales such as motors and compressors, also contributed meaningfully to the performance.
The company’s subscription business, which combines hardware and services, is rapidly expanding. In 2025, LG plans to further strengthen its subscription-ready product lineup and customer care services, while also accelerating the global rollout of its subscription model.
In the media and entertainment solution business, from this year, LG is integrating its display-based businesses – including TVs, IT (laptops, monitors) and ID (commercial displays) – to generate synergy in its webOS-based advertising and content platform, traditionally centered around smart TVs.
LG’s 2025 TV lineup introduced enhanced AI features such as personalized content recommendations, superior picture quality and immersive sound. New products like the ultra-light LG gram Pro AI laptop and the portable LG StanbyME 2 lifestyle screen received positive responses from global markets. The commercial display segment also secured several large-scale international contracts.
The vehicle solution business, continues to expand sales of high value-added products, especially in in-vehicle infotainment (IVI) systems, while diversifying into automotive content platforms. LG Magna e-Powertrain is strengthening its competitiveness through advanced motor and inverter technologies and is enhancing operational capabilities at global production sites to support long-term growth. Meanwhile, the automotive lighting business is accelerating development of next-generation technologies, such as high-resolution and intelligent lighting systems, while improving overall efficiency.
The heating, ventilation and air conditioning (HVAC) business began operating as an independent Company in the first quarter. By focusing business capabilities on the essence of the order-based HVAC business and the characteristics of customers, the company is increasing its contribution to profitability.
In the commercial HVAC space, LG secured major overseas contracts in markets such as Singapore, thanks to its ability to provide localized, tailored solutions. Going forward, LG aims to make HVAC a core pillar of its B2B portfolio by leveraging its proprietary technologies in compressors, fans, heat exchangers and AI engines.
In the residential market, LG plans to maintain its leadership with AI-powered innovations. Additionally, in industrial and power-generation sectors, the company is actively pursuing new opportunities with large-scale chiller systems.
These figures are tentative consolidated earnings based on K-IFRS provided as a service to investors prior to LG Electronics’ final earnings results, including net profit. Details regarding each division will be announced officially later this month.
LG has once again left a lasting impression on visitors to ISH, one of the world’s biggest annual tradeshows for HVAC, water and sanitation solutions. Held in Frankfurt, Germany, the event highlighted LG’s extensive range of integrated heating solutions customized for diverse environments and spaces, including high-efficiency residential heat pumps and large-capacity commercial systems. Tailormade for the European market and compliant with the European Union’s F-gas Regulation, LG’s products exclusively employ refrigerants with a low Global Warming Potential (GWP).
A major attraction at LG’s booth, the Hero zone introduced ISH visitors to the exceptional Therma V R290 Monobloc air-to-water heat pump (AWHP) for residential applications. Displayed beneath a captivating hanging façade at the center of the zone, the new Therma V boasts a sleek, minimalist design, quiet operation and outstanding cold-climate performance, thanks to LG’s advanced scroll compressor. Designed with user comfort and the health of the planet in mind, the Therma V employs R290 refrigerant, which has a GWP of 3, to reduce carbon emissions.
LG also showcased the Monobloc G and Cascade Control Unit, two sophisticated solutions suitable for multi-unit apartment buildings and large homes. The Cascade Control Unit offers flexible scalability, allowing users to add up to eight outdoor units to their HVAC system. This adaptability not only meets varying heating demands but also optimizes energy efficiency, thereby contributing to the reduction of HVAC running costs.
Another notable exhibit was the new LG heat pump water heater (HPWH) with R290 refrigerant. Displayed in a booth area designed to resemble a stylish European kitchen, the versatile HPWH R290 utilizes both air and electricity as energy sources, achieving greater efficiency than traditional electric or a gas-powered water heaters. Its simple design ensures compatibility with various installation environments and customer needs, offering seamless integration with various types of indoor units, such as control, hydro and combi.
In response to recent EU restrictions on refrigerant usage, LG has launched a complete lineup of reliable commercial HVAC solutions utilizing R32 refrigerant (GWP of 675). Visitors learned about the innovative, large-capacity Inverter Scroll Chiller, which leverages twin inverter scroll compressors to maximize cooling power and operational efficiency. The Inverter Scroll Chiller can be integrated with LG’s Building Energy Control (BECON) CPM system, which utilizes advanced AI technologies to simplify control and monitoring of LG’s commercial HVAC solutions.
The Multi V i R32 variable refrigerant flow (VRF) solution was another attraction at LG’s booth. Incorporating the company’s AI engine, the Multi V i intelligently manages temperatures across multiple indoor spaces. This VRF solution includes a full package of integrated solutions, including a number of safety features and systems designed to enhance stability and reliability, and provides time-saving troubleshooting assistance with Smart Diagnosis.
LG, a pathfinder for innovative heating, has been at the forefront of HVAC innovation for several decades and continues to show the way forward. With its comprehensive exhibit of efficient and sustainable HVAC solutions at ISH 2025, the company reaffirmed its commitment to decarbonization and to paving the way to a better future for all.
At LG, innovation extends beyond technology – it’s about creating meaningful experiences that inspire change and shape the future. This vision comes to life through LG College Day, an immersive program that connects students with LG’s corporate culture, emphasizing sustainability and real-world innovation as core values.
Recently, over 50 Princeton University Korean language students visited LG Electronics North America’s headquarters in Englewood Cliffs, New Jersey. The visit provided a firsthand look at how LG is pioneering the future through cutting-edge technologies, insightful discussions and hands-on learning experiences.
For some, LG College Day is more than just an educational visit – it’s a gateway to a future career. One former participant was so inspired during his visit that he later joined LG as a full-time employee, underscoring the program’s role in connecting top talent with real-world opportunities.
The visit began with an introductory session where students explored LG’s business strategy, technological advancements and global impact. A highlight of the session was a dynamic panel discussion featuring LG executives and industry experts, who shared valuable insights on career development, leadership and the future of technology.
Students then stepped into LG’s showroom, where they interacted with groundbreaking innovations such as the LG SIGNATURE OLED T – the world’s first wireless and transparent OLED TV – and the LG StanbyME, a portable wireless screen acclaimed for maximizing users’ on-the-go productivity. The OLED Flexible Signage display delivered an immersive visual experience that brought images to life with stunning clarity and realism.
Next, students explored LG’s Home Appliance showroom, where they witnessed AI-powered innovations that are transforming everyday life. From smart refrigerators that suggest optimal recipes to AI-driven washers that optimize laundry cycles, LG continues to set new standards for intelligent home solutions.
A visit to LG’s cutting-edge Virtual Studio offered a behind-the-scenes look at the creative process behind the company’s global marketing campaigns. The studio, a high-tech production space for commercials and product photography, highlighted LG’s emphasis on storytelling and branding.
Students also gained insight into LG’s environmental and social initiatives, including the Endangered Species Series, the Pollinator Garden and LG’s LEED Platinum Certification – reinforcing the company’s commitment to sustainability.
Beyond technology and business insights, LG College Day provided students with an opportunity to engage with LG’s Human Resources team, exploring various career paths and business opportunities within the company.
Jung Kyu-hwang, CEO of LG Electronics North America, emphasized the importance of fostering connections with the younger generation: “By engaging with young people, especially Gen Z students, we’re not just showcasing our innovations – we’re building connections for the future.”
LG College Day continues to grow as a platform for inspiring future leaders, bridging the gap between academia and industry while celebrating the synergy of innovation, corporate responsibility and Korean culture.
