This tip is only for HP TouchPads running webOS 3.0.5
Cycle Email NotificationsWhile
have always been a hallmark feature of webOS, the ability to was a great enhancement because it allowed you to do things like view and dismiss one email at a time instead of all the new emails that recently arrived. Unfortunately, you still needed to view the email notifications in the order they arrived so there was no way to keep a notification in the dashboard while still moving to the next email. Your only choices were to leave all the remaining notifications in the dashboard, dismiss one email notification, or dismiss them all. But, as is another hallmark feature of webOS, the homebrew community created a nice workaround for this issue.
If you install the Cycle Email Notifications patch by GMMan, available in Preware or webOS Quick Install, your email notifications will automatically scroll from one message to the next every 5 seconds or so. They will cycle while you are working on the TouchPad, in exhibition mode, or even on the lockscreen. While it may take a little bit of time if you have a lot of notifications, this will at least allow you to keep or dismiss only the email notifications you want.
a2t.imgMuGvDCgKeGY
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By Filip_IT
      Hello
      I have login issue on a brand new LG TV 55UR640S0ZD there I  want to create content with content manager and create Groups with Group Manager 2.0.
      I´m trying to login to Dashboard with chrome and Internet Explorer browser which is connected to wlan with IP address:
      link hidden, please login to view  Here it says to Input Password and I have tested
      0000
      000000
      00000000
      1157
      admin
      Without success, what is the default password?
      I have reset the TV from Hotell mode menu and ordinary Menu to factory default but does it exist any other way to reset TV?
      How can I get access to my TV?
      All help is appreciated
      BR. Filip
    • By dinoc
      I have an LG TV with Web OS 13.30.56 and the HBOMax app was replaced by MAX app.
      Since installing the new app I get 50+ per day ads notifications from Max app with the same add, every day , 50 notifications per day.
      I've made a video with the problem to understand it better:
      link hidden, please login to view Where can I report this problem to get it fixed?
      Please feel free to move this topic to a more appropriate area, if needed.
      Thank you
    • By Kevin_Idaho
      Our LG TV was just updated with the latest software - before when the TV was turned on it was set to the previous input (one of the HDMIs).   Now it appears to be sent to the Home Dashboard and I have to manually change it to the desired HDMI input.    Does anyone know how to fix this?    Thanks!
