WebOS Quick Install 4.5.0 goes open source
The founding utility of the webOS homebrew scene has gone open source. WebOS Quick Install was first released by
back in 2009 and it has served as the backbone for ever since. The robust Java-based desktop app runs on Windows, Mac, and Linux, installs apps, themes, kernels, and patches from multiple homebrew sources, and with the latest update to version 4.5.0 has gone open source for the masses. Open source seems to be .
Despite its vital function in the webOS homebrew and open source development scene, WebOS Quick Install to this point has been a closed source application. 4.5.0 changes that, open sourcing both Quick Install and the webOSLib Java library. By open sourcing webOSLib, developers will be able to utilize the library to install drivers (open sourced by HP), list connected webOS devices, transfer files, execute shell commands, install apps and patches in compliance with webOS homebrew standards, and more.
Both and are up on GitHub now in full open source. You can download and compile yourself, make and submit improvements, or even fork it off into your own webOS homebrew project. Whatever floats your metaphorical homebrew boat. And, as always, if you find yourself appreciating the work Robitaille's done, hit up the source link below to offer up a donation of thanks.
a2t.img5GzobgkB8-E
    • By SHawk
    • By Sqwazy
    • By Bella Lee
    • By Gabriel Śmiech
