USB HDD that will work on my TV
By Horniak
By CJ Catalano
By JRay
By Calvinder
Any suggestions
- 8 answers
- 12,902 views
- 4 answers
- 28,696 views
- 3 answers
- 20,238 views
- 3,481 views
P.T.
I have a LG G3 Oled Tv 65 inch. I want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of a USB HDD that will work on my TV .
Peter
