This is NOT an LG site, only a user to user support site.
Try one of these, for watching camera footage on a phone or PC/Laptop:
    • By wallyricks
    • By Pranay Mokida
    • By Tobin
      Tobin
    • By Luka Pantsulaia
    • By Prashant Chavan
      Please add Jio TV app in upcoming software update.
