I've done a hard reboot on my 60LA TV because the remote wouldn't connect ( I think the issue is the IR sensor ) but now when the setup comes up I can get through the menu using the buttons behind the tv. But when it gets to accepting terms and conditions it won't let me move down to accept button. I can check and uncheck the agree check boxes by pressing ok button but can't navigate with the arrows. Anyway passed this so I can just use the tv with my inputs??
    • By mean2
    • By atcronin
    • By PVD
