How to Get Tidal app on a LG TV
By Rolivhuwa Muelelwa
I have been struggling with the Tidal App on my LG C1. You play music, but it random stops playing. Both on Wired connection and WiFi connect. I basically can't listen to any full song, without the audio randomly stopping.
By Zoran Nedovic
There is no TIDAL in the offer of applications on my LG 55 OLED B8 (software 05.40.09)!
Does anyone know why?
Thanks!
anna groove
It seems that Spotify is easy to use on many TVs, but Tidal is different. How can we play Tidal music on an LG TVs?
Here’s one method: Use the AudFree Tidal to MP3 Converter to save the songs onto a USB drive. Then, insert the USB drive into the TV.
