Mac Mini HDMI1 output does not wake up MyView 32SR83U-W Smart Monitor
Hello, Not sure if you can help, the user manual certainly CAN'T help!
When I first setup the monitor, It asked what the default mode will be, I selected PC, and default input HDMI1
I have it connected to a MAC Mini M4 with HDMI cable, every time the Mac Mini goes into sleep mode or I leave for a while, the Monitor Switches off,  cannot be woken up by the mac mini by hitting the keyboard or mouse as per normal monitor.
I have to power ON the monitor with the remote and manually select HDMI1 to go back to using the Mac Mini
I can't find the settings section to check the Default Power on or wake up Mode settings are, the manual does not provide this information.
Very annoying!
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Gregor Huc
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
      Key Specifications:
