LG43UT73006 Satellite tuner installed in uk
Looking online this number is for a TV not a satellite. The built in freesat  tuner on my LG SM8600PLA does not have a favourite programme button on the magic remote picture quality not as good as Sky through Sky plus HD box.
    • By OhmorrowSouthWales
    • By Tony Levy
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Shahzad heydari
      Add Yahsat Satellite  in Middle East Product like UH770V  😡😡😡
    • By Mahboobeh Nazouri
      How can I add yahsat to my satellite list webos lg tv????
