Cut the Cord and Enjoy 100+ Free Channels on Your LG Smart TV!
By anna groove
LG Radio+ Brings LG Smart TV Users Free Listening to a Wide Range of
Popular Podcasts and Live Stations, Also Accessible From LG’s Audio Devices
SEOUL, Dec. 20, 2024 — LG Electronics (LG) has launched LG Radio+, the company’s ad-supported audio streaming service, now available on LG smart TVs running webOS 6.0 and above. This new service allows users to effortlessly access a diverse selection of podcasts and radio programs. For a streamlined user experience, LG Radio+ will work with the LG ThinQ app,1 providing users with a convenient way to access and enjoy their favorite audio content no matter where they are in the room.
To offer a curated list of audio streaming content, LG has partnered with global radio and audio provider Radioline, giving users an all-in-one audio platform allowing effortless access to news, sports, music and more. Available in the U.S. and Korea, LG smart TV users can explore a range of live stations and podcasts, with options such as NPR, CNN Radio, Fox Radio or The Joe Rogan Experience in the U.S., or popular local stations and podcasts in Korea.
The LG Radio+ app can be accessed from the Content Store or Apps or by using the voice search function of the LG Magic Remote, providing a fast and convenient way to discover new listening content.
For quick and easy exploration, LG Radio+ has an intuitive interface with a comprehensive channel list, presenting popular audio channels on the On Air page, alongside a personalized selection of favorite channels. Users can navigate the On Air and Podcast pages to access their desired audio streaming content, while the Featured page provides a dynamic view of trending music, updated in real-time to highlight the most popular or season hits. This enables users to search, discover and enjoy their preferred audio content with ease out of a large library of over 14,500 channels in the U.S. and over 440 available in Korea.
As part of LG’s commitment to enhancing user convenience and connectivity across the company’s life-enriching products, listeners will be able to access LG Radio+ through the LG ThinQ app,2 enabling enjoyable audio streaming on LG audio devices with minimal effort. What’s more, LG Radio+ will also be available to access through the My button on xboom speakers in 2025.
LG continues to elevate the user experience with a broad range of content and an intuitive user interface, making it effortless to explore and enjoy audio entertainment. To learn more about how LG is enhancing the audio experience, visit
1 Available at a later date in 2025.
2 Accessible via xboom category
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
By jcol5786
A few years ago I bought a 43" LG Model 43UK6200PUA, manufactured in 2018. I'm from Canada but I purchased this TV in the US. It was a store demo unit on for a great price. I took it home to Canada, set the location to Canada and setup up in our bedroom. It has been working fine with our Fiber TV service as well as Netflix, Amazon etc. We also to have a 60" LG TV in the living room which was purchased in Canada. This TV is similar in age to the one in the bedroom. Recently I started watching the LG channels on the living room TV. I hadn't really paid much attention to them before but now I enjoy them. My problem is that the LG channels do not work on the bedroom TV. I suspect because it was purchased in the US but located in Canada. With the location set to Canada the LG channel guide populates and shows what's on however when I select a program I get the following message.
