    • By David Daul
    • By Horniak
    • By JRay
    • By P.T.
      I have a LG G3 Oled Tv 65 inch. I  want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of  a USB HDD that will work on my TV .
      Peter
    • By Calvinder
      One suggestion was to go to Settings>all settings>general>AI Service>Voice recognition service and change to LG ThinQ.
      But the  Voice recognition service tab is gone. There is only voice recognition settings tab
      I would rather not have to reset to factory settings unless there is a way to save / export my current seating's
      Any suggestions
