Incoming call
All webOS smartphones are, at their core, a phone. So it's only fitting that you know how to answer a phone call when one is received or you will be unable to utilize one of the most basic functions of the device. And because answering a phone call is such an important feature, you are actually given quite a few different ways to perform this action. As long as you can hopefully remember at least one of these options, you should never have to miss answering a call. And keep in mind that certain models of webOS phones--such as those with a slide-out keyboard--give you even more options, so make sure you know exactly what your specific type of hardware is capable of when reviewing the different options below
  1. If you have a
    set in the Screen & Lock app and you have currently passed the "Lock After" timeframe and you can an incoming call, the caller ID will display at the top of the screen with the caller's name and number, and you will have an Answer iconicon on the bottom of the screen. Just as when your phone is normally locked and you turn on the screen, just drag that icon up above the "Drag up to answer" line to answer the call or do nothing to ignore it.
  2. If you are currently using your phone or the password "Lock after" time has not been reached, then you should be presented with a notification on the bottom of the screen with the caller ID info and then two buttons: a green button to answer and a red button to ignore the call. Just tap the green button to answer. Note that if you , just can still tap on the notification the dashboard to answer the call
  3. For those phones with a , which would include any of the phones in the Pre-series or the Veer, you can also slide open the keyboard to answer the call. No fumbling with on-screen buttons necessary
  4. Finally, if the phone is Touchstone-enabled and is currently charging on a Touchstone when a call is received, you simply need to pick up the phone from the charging dock to answer the call.
And don't forget that you always by pressing the power button once or twice, respectively, if you do not want to actually answer the call. Also, if you have your and set up to receive phone calls, you will get a similar option at #2 above where you just have to press the green answer button in the phone call notification to answer it.
a2t.imgSbxQKuWHnOM
    • By The Old Man
      Hey LG
      Yes I am NOT happy
    • By Call Me
      0822-46435524 . Layanan ini tersedia 24 jam, jadi kamu bisa menghubungi mereka kapan saja, baik melalui telepon rumah maupun handphone
      0822-4643-5524. Layanan ini tersedia 24 jam, jadi kamu bisa menghubungi mereka kapan saja, baik melalui telepon rumah maupun handphone
    • By Low Grade
      i thought of using my handphone to act as a remote control for the TV.............but it will only work with WiFi ??!!
      i had BlueTooth still turned on..............TV is using LAN connection only.........and the phone can no longer control the TV (the phone can control the TV with WiFi on)............is this normal ??
      many thanks in advance............
    • By Asrar ul haq
      Hey,
      I recently brought a LG C1 OLED tv along with a LG SP9YA soundbar. I have been having issues to screenscast from my Samsung s21 plus phone on the TV when connected to sounbar. There is a clear lag and eventually screencast gets disconnected saying signal for smart view screencast is bad (reconnecting could help, but it never does). Updated all the apps on TV and phone but it didn't resolve the issue.
      I dont understand what to do
    • By Youssef Abdallah
      I’m trying to cast from an app on my phone to LG QLED but the app on my phone is telling me that (recording is prohibited,video stopped because TV output is ON or device is recording . Please disconnect TV Output or stop recording and try again) I really have no clue about this issue and what to do !
