PreCentral: Bookmark File Manager folders
By Lorenz
By MinoDc
Hi to all.
What do you think
By Jonatan de la Torre Gómez
By JayDee
With so few apps available, I find the need to use the janky included browser. It's bad enough but having to type in my account AND password every time? I love that the apps I *can* download work great -- even when I'm at the end of my data plan and everything is hampered by the slower speed!
You'd think something called "WebOS" would work with.. the web... a little more reliably. Let us download JioPages, OpenBrowser, SOMETHING that makes our TVs easier to use.
By odesanmi kolade
I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
