Freeview app
I have an LG43UN71006LB TV. I don't have an option to download the Freeview app. When I search for it in Content it isn't found. However I was told that the app should be available on this model. Would appreciate if anyone could confirm I this is the case and if so why it isn't available to download.
    • By John Phillips
      Can you upgrade Freeview to Freeview Play??
      Regards
      John
    • By Wingwalker
      LG Television.   Device ID: LG24-K8LPN2   Rowridge transmitter -  BH22 (Dorset)     I purchased a new LG television last week from Curry's but am having a repeated issue on the Freeview channels. The issue is that despite several attempts at clearing the memory and doing an automatic retune on digital channels - after an overnight switch off, they have all gone again by morning.    I can view everything as normal during the daytime - including if the television has been turned off for a number of hours. The issue arises when I turn on the TV the following day after it has been turned off overnight. I am continuously left with just five channels starting at number 301 as per the image below.     I have a set top box from BT and have tried retuning the TV both with the box connected, and without. The results are the same each time, no matter what I try. Daytime all is well, but after an overnight period I am left with the screen above.     As you can see from the image below, everything is as it should be after yet another retuning session this morning. Please can you help?
    • By Wingwalker
      LG Television.   Device ID: LG24-K8LPN2   Rowridge transmitter -  BH22 (Dorset)     I purchased a new 50" LG television a couple of weeks ago from Curry's but am having a repeated issue on the Freeview channels. The issue is that despite several attempts at clearing the memory and doing an automatic retune on digital channels - after an overnight switch off, they have all gone again by morning.    I can view everything as normal during the daytime - including if the television has been turned off for a number of hours. The issue arises when I turn on the TV the following day after it has been turned off overnight. I am continuously left with just five channels starting at number 301 as per the image below.     I have a set top box from BT and have tried retuning the TV both with the box connected, and without. The results are the same each time, no matter what I try. Daytime all is well, but after an overnight period I am left with the screen above.     As you can see from the image below, everything is as it should be after yet another retuning session this morning.        My previous TV was a JVC Fire and used to stop receiving the Freeview signal just after 1am each morning. I did a bit of googling and found out it was an energy saving thing to ensure the TV isn't left on all night if you fall asleep in front of it. With the Fire TV was there was a way to override this in the settings, although I never did anything about it as 99% of the time I was already in bed and therefore not a problem. I'm wondering therefore if this issue on my LG unit is in some kind of similar vein and just needs something to tell it to stop doing this reset???    Can anyone help me please as I'm getting sick of doing an auto tune every morning.    Many thanks in advance.   David.
    • By Stephen Davies
      I have a 2020/21  LG Nano49 and a Humax 4000T Freeview box. My aerial lead goes into the Humax and then connects to the TV's aerial socket via the RF out on the Humax. All has been fine since buying the TV last December, until Saturday.....
      Suddenly the HD picture pixellated badly and then the 'no signal' screen came up. Trying to figure out what was happening, I found that I was only able to tune & access just a third of what I'd been able to before (and NO HD ones!) and the only way that I could both tune and access all through the TV, was to have the Humax box switched on. It didn't have to be selected in the inputs, just switched on. If I tried switching the box off, the HD channel being viewed, would disappear within a minute or so and the 'poor or no signal' screen would take its place, although I was still able to access some none HD channels.
      Isolating both the Humax box and the TV didn't produce any answers : the Humax tuned and displayed ALL the channels when its input was selected and when the aerial lead was removed from the box and plugged directly into the TV, no problem at all....ever channel able to be tuned and displayed.
      Even tried another identical Humax 4000T and had the same results.
      In conclusion, the TV tuner appears to work as it should when the aerial is connected directly to it and separately, the Humax box doesn't seem to have any issues when it's input is selected, but now, if I want to continue with having my Freeview recorder and TV connected, the ONLY way that I can have ALL the channels viewed through the the TV's input is to have the Humax box switched on all the time.
      Hope someone can throw some light on this issue, as I'm stuck......?
    • By LGUSERINDIA
      I brought LG LED 124cm 49UK7500  UHD/4K from India to UK. Will the TV support UK TV channels such as BBC and others through a TV Aerial cable or do i need to buy a FreeView box?
