"● Real-time Video Streaming
    • By David Daul
    • By CJ Catalano
    • By JRay
    • By Dennis Radliff
    • By P.T.
      I have a LG G3 Oled Tv 65 inch. I  want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of  a USB HDD that will work on my TV .
      Peter
