disable lightbarWhen the physical button on the original Palm Pre was replaced with a virtual capacitive button on the Pre Plus, there was more than just a change to the physical appearance of webOS phones. While both the physical button of the Pre and the capacitive button of Pre Plus performed the same functions to
or provide blink notifications since , the LED light of the Pre Plus would also light up any time an app was open and active on the device. This may be a nice reminder that the LED light also doubles as a home button, but it can also be quite annoying. All webOS devices since the Pre Plus has continued this functionality, with no way to disable it if you would rather not have the LED light up whenever you are working in an app.
Not willing to take no for an answer, the webOS homebrew community stepped up and provided a homebrew patch to fix this issue. All you need to do is install the "Disable LightBar" patch from developer Herrie and that default behavior of the LED will now be disabled. It will still blink for any app notification, it just won't light up every time you are working in an app.
a2t.img0ENkA71aoWE
    • By mycop
      Greetings.
    • By 43UR81006LJ
    • By Ramya Shyam
    • By StanJ
      I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
      On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
      I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off,  HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
      Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
      Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes).  It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
    • By duckie133
      VERY ANNOYING!!!!!!!!!!
