Tweaks - Email Compose View optionsThe email app on your webOS smartphone does not offer you a lot of options on how to customize it to your liking, with your only options available are to set your notification sound,
or , adjust your , or choose your . However, thanks to the webOS homebrew community you now have some additional ways to adjust your email app experience. Homebrew developers Momouton and anseld1986 have released the Email Mega Mix as a Tweaks-enabled patch that took many of the best email-related patches available and then improved on it even further.
While there are a variety of enhancements available in this patch, one section that you may find useful is the "Compose View Options." In this section, you can adjust six different tweaks for when you are writing or replying to an email. Three of the tweaks allow you to display or remove buttons on your email, while the other three will give you a pop-up confirmation screen depending on the action you want to perform.  To activate any of these, just install the Email mega Mix patch (available in Preware or webOS Quick install) and then open up the Tweaks app on your device. Navigate to the Email section and find the "COMPOSE VIEW OPTIONS." Choose any or all of the following:
  • Display Priority Button: Add a "!" button to toggle the importance level of the email, thereby marking it as "urgent" to the message receiver
  • Display Discard Draft Button: Add a "trash can" button to quickly discard the current email, instead of having to needing to
  • Display Save Draft Button: Add a save button (it looks like an old school floppy disk) to save the current email draft. This just saves the current progress while still leaving the email up for editing
  • Require Send Confirmation: Add a confirmation pop-up after you hit the "send" button to confirm that you would really like to send the email
  • Require Save Confirmation: Used in conjunction with the "Display Save Draft Button" above, you can add a confirmation pop-up asking if you would like to save the draft.
  • Require Discard Confirmation: Used in conjunction with the "Display Discard Draft Button" above, you can add a confirmation pop-up asking if you would like to discard the email when you tap the trash button.
Once you toggle any of these tweaks, you will need to close and then re-open the Email app for them to take effect. There is no need to the whole phone.
a2t.imgi9JKwGYQo70
    • By Andreas Boyatzoglou
      Model: OLED55BX3LB
      Viewing videos from
      link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site  cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
    • By Fricassee
    • By Maria D
      How to change view from 16:9 in movies to fit full screen
      LG QLED B22
    • By Batman
      I have a LG 43QNED756RA AEK Smart TV
      If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
      So I cannot Move or Edit Program Numbers or Delete
      Any help and comments would be appreciated
    • By Kemal Sözüner
      I recently bought a LG TV with WebOS version 8.1 and have a frustrating issue.
      I have a usb disk with all my family photos & videos archive in it.
      We love to browse through the pictures and videos on big screen.
      But current LG TV media player displays either pictures or videos. I want to see them in the order they were captured.
      It would be great to enable this feature when "Photos & Videos" filter is selected.
