Android 4.4 KitKat available for HP TouchPad
As of mid-November, 2013 KitKat is still very much a work in progress. Developer flintman has posted a build of an Android Open Souce ROM called Evervolv at the xda-developers forum.
At this point Bluetooth doesn’t work, the stock web browser doesn’t work, and there’s a risk of data loss — and since the browser doesn’t work, you may need to create an app-specific password to login to your Google account if you use 2-step verification.
The options to reboot into recovery are also broken for now — but you can always reboot your tablet manually to get to the Moboot bootloader.
In other words, if you want to help test for bugs, go ahead and install the software. If you want a stable operating system on your HP TouchPad, you should probably wait a little while.
KitKat also takes up more space than some earlier versions of Android, so you may want a larger system partition. Developer iMarck90 has posted experimental builds of ACMEInstaller at the RootzWiki forum. It’s designed to give you larger system partitions.
Read more:
Sent from my iPhone using 2
  • 5 months later...
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By Wiliam
      Having a LG OLED65CX6LA 2 FROM 2021 / software version is 04.41.45
      Living in Switzerland as a English expat
      BBC IPLAYER IS NOT PRESENT IN APP STORE
      Please advise or help. Thx
    • By Puja aingh
      Respected LG Team
          Please provide me the app AIRTEL XTREAM and VOOT and EROS NOW this app is not available in LG content store
      Complete with Next-Gen Cinematic Technologies, LG OLED TVs are Set to Uncover
      the Hidden Story and Shine Light on the Action of Prime Video’s Latest Hit Series
      SEOUL, April 26, 2023 — Starting this week, LG Smart TV owners worldwide can enjoy Citadel, Prime Video and Amazon Studios’ epic spy-thriller series and the latest global sensation in streaming television. With LG OLED TV’s self-lit technology allowing for deep blacks and life-like color, viewers are placed at the center of the action-packed Citadel universe and can enjoy the show with intended color, aspect ratio and frame rate, thanks to Automatic Filmmaker Mode.* LG OLED TVs also feature Dolby Vision® for stunning ultra vivid picture and incredible immersive Dolby Atmos® sound, which further elevate the cinematic experience.
      Starring Richard Madden and Priyanka Chopra Jonas, Citadel is set after the fall of the titular spy organization, as two spies attempt to piece together what happened. The two spies embark on a mission that takes them around the world, all while contending with a relationship built on secrets, lies and a dangerous-yet-undying love.
      Citadel premieres exclusively on Prime Video on April 28, with two adrenaline-fueled episodes, followed by a new episode released weekly every Friday through May 26. Citadel will be available in more than 240 countries and territories worldwide.
      To mark the launch of the cinematic new television series, Prime Video and LG teamed up to bring the characters and high-tech world of Citadel closer to its fans, through a series of exclusive visuals, rolled out across multiple channels, including online, in-store as well as digital billboards in New York’s Times Square and London’s Piccadilly Circus.
      This is not a first for Prime Video and LG, as it continues a long relationship between the streaming service and smart TV manufacturer. Both have a combined goal to deliver the best viewing experience to millions of customers across the world who stream Prime Video’s great content with the LG OLED evo superior technology.
      From launching link hidden, please login to view on LG OLED TVs in 2015, to movies and series in 2021 and to bringing opted-in for customers to discover the best Prime Video content in 2022, LG’s long relationship with Prime Video continues to lead innovations in the home watching experience.
      “At Prime Video, we are always looking for new ways to innovate and provide our customers the best viewing experience,” said Andrew Bennett Head of Global Video Partnerships for Prime Video, MGM+ and Amazon Freevee. “Our relationship with LG and joint commitment to customers has allowed us to continuously raise the bar with new technology that enhances the overall user experience.”
      This comes as LG aims to boost marketing efforts designed to offer customer value through the delivery of unique experiences across a variety of touchpoints. Prime Video was a natural partner to expand LG’s marketing relationship given their global reach, continued tech innovation and engaging content. LG plans to introduce more exciting collaborations like this in the future.
      “LG is actively collaborating with its content partners like Prime Video to provide customers with an engaging experience on the big screen at home and beyond,” said Chris Jo, senior vice-president of platform business at LG Electronics Home Entertainment Company. “We are happy to kick off this initiative with Prime Video, whose global partnership and shared passion for innovation through the years helps us provide a best-in-class experience for customers.”
      * Available on LG 2023, 2022, 2021, 2020 4K and 8K TVs.
