Any idea of recovering Android Lost Contacts?
By PoeyYong Wong
I have this LG OLEDXXCXPTA TV with Sonos for over 2 years. Except in the beginning where I have some issue with volume control with Sonos, it has been working fine. Recently I am encountering problem controlling volume with LG remote for my Sonos Arc. The only way I could get it back to work is to reset the LG TV to initial setup like what I have done 2 years + ago to regain volume control back with a new setup.
However this time it seems to be different, I continue to lose volume control unexpectedly and I cannot see a trend. The latest being when I use the Netflix app to watch shows on my LG TV.
Any suggest to resolve this?
It is getting frustrating to keep resetting TV to initial setup so that I could use the remote for volume control.
By Ayon Mondal
Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN. Please solve the issue as soon as possible and let me know how to fix it. This is the serial number of my TV :- 64387205122152TRFLJL
By SGray
By swattt
Dobrý den,
Při sledování Smart TV LG s android boxemTesla se mi často vypíná obraz (problikne) a v rohu se objeví HDR. Nevím si rady v TV to nejde zakázat tak už opravdu nevím?? Kabel?? Mohl by mi prosim někdo dát někdo poradit co s tím?? Děkuji.
