If you want to start working on your future apps already, there's no need to wait.. it's all going to be based on this:
Just go to and select Moonstone UI, the whole UI looks just like on WebOS commercials, check for yourself. You can start building your apps already!
  • 2 weeks later...
News from Seller lounge:
Dear Sellers,
Thank you for using LG Smart TV Seller Lounge.
LG Electronics is currently under system operation to launch applications on WebOS TV, the new product of 2014.
We ask for your understanding as the Application List may appear differently than before while the system operation is being proceeded. It will return to original list as soon as the procedure is done. We will do our best to complete the operation promptly to reduce any inconvenience you may experience.
Seller Lounge will continue to strive to provide you with better Smart Services.
Thank you.
LG Smart World Seller lounge.
  • 1 month later...
    • By JamesH
    • By DavidSr
    • By Fredrik Andersson
    • By akhil7j
    • By GVK TEJA
      Please add Jio cinema to WebOS store. I bought it LG TV to watch world cup but i can't. I'm so regret.
      TV model: 43LJ554T
      OS: WEBOS
      Version: 6.10.35
