    • By coyote
      I'm surprised by how few Settings there are.  Is there an Android Settings App?
    • By Ayon Mondal
      Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN.  Please solve the issue as soon as possible and let me know how to fix it.  This is the serial number of my TV :- 64387205122152TRFLJL
    • By SGray
    • By swattt
      Dobrý den,
      Při sledování Smart TV LG s android boxemTesla se mi často vypíná obraz (problikne) a v rohu se objeví HDR. Nevím si rady v TV to nejde zakázat tak už opravdu nevím?? Kabel?? Mohl by mi prosim někdo dát někdo poradit co s tím?? Děkuji.
    • By Deepak Suresh
      SunNXT app looks different and old in WebOS and Android TV app is great now and latest.
