LG Begins Roll Out of Impressive 2014 TV Lineup
for AI Data Centers
LG’s New OLED evo Exemplifies Visual Perfection With Striking Brilliance and
Unrivaled Blacks, Along With AI Personalization for a Tailored User Experience
SEOUL, Jan. 5, 2025 — LG Electronics (LG) today unveiled its 2025 OLED evo lineup, highlighting a range of advanced TV offerings, including the world’s first true wireless OLED evo M5, and OLED evo G5 models. With LG’s latest α (Alpha) 11 AI processor Gen21 at its core, the latest OLED evo models present unparalleled OLED picture quality with impeccable blacks, exceptional brightness and advanced processing capabilities. Powered by AI-driven personalization, the LG OLED evo offers a customized experience tailored to each user and showcases the pinnacle of OLED innovation for an elevated home entertainment experience.
The latest OLED evo TVs feature LG’s upgraded Brightness Booster Ultimate technology, which enhances light control architecture and light-boosting algorithms to achieve brightness three times higher2 than conventional OLED models. This significant boost in brightness brings fine details into focus across different brightness levels, resulting in a more vibrant and lifelike viewing experience.
LG OLED evo refines every detail to perfection with flawless blacks, accurate color reproduction and stable performance. The latest models achieve top-notch black levels in both bright and dark settings, producing vibrant and accurate colors. These advanced OLED displays have received UL Solutions’ “Perfect Black”, “Perfect Color” verification and are certified by Intertek for 100 percent color fidelity. The 2025 OLED evo TVs also boast rapid brightness and color temperature stabilization, earning TÜV Rheinland’s “Quick Stability with Image Quality” certification.3 This ensures users experience exceptional picture quality immediately upon powering on the TV.
New for 2025, LG’s latest OLED evo 4K TVs support Filmmaker Mode® with Ambient Light Compensation4 – an advanced version of Filmmaker Mode developed in collaboration with the creative community. This feature accurately detects the lighting conditions of the viewing environment and automatically adjusts the picture settings to maintain the filmmaker’s original intent, delivering a truly cinematic experience in various lighting conditions.
Elevating its reputation as the ultimate choice for gamers, the latest LG OLED evo TVs boast several features tailored to gaming, including the industry’s first 4K 165Hz5 Variable Refresh Rate (VRR), certified by NVIDIA® G-SYNC® and AMD FreeSync Premium. The OLED evo models enhance gaming with tear-free, stutter-free gameplay, minimal input lag and up to 165 frames per second. The OLED evo TVs are the first to receive ClearMR 10000 certification by VESA, ensuring flawless motion and seamless experiences even during fast-paced action sequences.
Powered by the advanced Alpha 11 AI Processor Gen2, the 2025 OLED evo models provide enhanced picture and sound quality. Deep learning algorithms meticulously analyze and refine low-resolution and low-quality images, enhancing them to a higher definition with pixel-level precision for natural and sharper visuals. Additionally, Dynamic Tone Mapping Professional offers expert-level control over HDR10 content for professional creators, allowing precise customization and fine-tuning of images for accurate color and detail representation in all viewing environments.
Complementing the impressive visuals, AI Sound Pro delivers rich, immersive audio with virtual 11.1.2 channels of surround sound, adjusting the tonal balance and clarity for an immersive, tailored listening experience. Designed with personalization in mind, LG’s newest OLED TVs boast AI-powered features that understand and adapt to individual audio and visual preferences. By analyzing over 1.6 billion image settings and 40 million sound profiles, the AI Picture/Sound Wizard tailors audio and visual modes for each user, ensuring a truly customized entertainment experience. These AI-driven features represent a new level of smart TV innovation, making the 2025 OLED evo models the most intuitive and user-centric TVs on the market.
The user experience is further elevated with a personalized journey that begins the moment the TV is powered on, courtesy of the AI Remote. AI Welcome greets users by name and provides tailored recommendations based on their preferences and viewing habits, while AI Voice ID adds convenience by recognizing individual voices, automatically switching profiles and delivering content suggestions that match personal tastes. Finding content on LG’s newest OLED evo TVs has never been easier, with AI Search6 leveraging a Large Language Model (LLM) to understand conversational context and uncover subtle user intentions. Access to Microsoft Copilot further streamlines the process, allowing users to efficiently find and organize complex information using contextual cues. For an even smoother and more engaging experience, the AI Chatbot proactively identifies potential user challenges and offers timely, effective solutions. What’s more, the Generative Image Gallery7 allows users to create custom backgrounds using voice commands, adding a personal and creative touch to the viewing experience.
OLED evo’s user-friendly webOS interface provides a personalized and streamlined experience to access content and settings more easily. The new home screen is faster, more convenient and increasingly personalized with enhanced UI and categories. Additionally, webOS now supports multi-platform integration with the Home Hub, seamlessly connecting with multi ecosystems, ThinQ and Google Home, for control of various IoT devices. By bringing together these versatile ecosystems and broadening cross-platform capabilities, users can effortlessly manage and control their smart home ecosystem through a single, intuitive interface on their LG’s latest smart TVs. Extending benefits beyond the initial purchase, the webOS Re:New program allows LG Smart TV owners enjoy the most up-to-date TV experience for the next five years.
LG has presented the first-ever OLED TV capable of transferring audio and video wirelessly, transforming the home entertainment experience with unmatched audiovisual performance. As the world’s first true wireless OLED TV, the latest M5 series delivers wireless audio and video transmission at up to 144Hz8 without latency or loss in picture and sound quality. Certified by NVIDIA G-SYNC®, this wireless OLED TV ensures a tear-free, stutter-free gaming experience, even during fast-paced action at 4K 144Hz. Building on this innovation, LG has extended its advanced wireless audiovisual technology to QNED TVs, bringing its core value of technological excellence and cutting-edge innovation to more customers.
LG’s OLED evo models have been recognized for their customer value and performance improvement, earning multiple awards including the CES 2025 Best of Innovation Award (for 83G5 models) and the Honoree title (83M5 model) in the Video Display category.
Visitors to CES 2025 will have the opportunity to explore how LG is elevating the home entertainment experience with its latest innovations from January 7-10 at the company’s booth (#15004, Las Vegas Convention Center). To stay up to date with all of LG’s announcements at CES, visit website and LG Global YouTube channel.
1 Equipped on G5 and M5 series.
2 Applies to 65/55/77/83-inch G5/M5 models, compared to the same sizes of conventional OLED models (B5 series) with a 10% window.
3 65-inch M5/G5/C5 series model has received this certification.
4 This feature works on models equipped with a light sensor.
5 4K 165Hz VRR is available on 55/65/77/83-inch G-series models.
6 Available in US and Korean market at the initial launch.
7 Available in US,UK and Korean markets at the initial launch.
8 Wireless transmission refers to the transferring of video and audio signals between a TV screen and the Zero Connect Box. Visually lossless, based on internal test results with ISO/IEC 29170-2 and measurement results may vary depending on connection status.
Showcasing the Evolution of the Company’s Ultra-Premium Brand, Advanced Lineup
Delivers Enhanced User Experiences and Enriched, Connected Living
SEOUL, Dec. 30, 2024 — LG Electronics (LG) is unveiling its expanded second-generation LG SIGNATURE lineup at CES 2025 in Las Vegas (January 7-10). Exhibited under the Live Beyond brand theme, the latest LG SIGNATURE range features exceptional products that integrate cutting-edge technology and sophisticated design to deliver enhanced usability, seamless connectivity and an unparalleled smart home experience.
The second-generation LG SIGNATURE lineup builds on its signature minimalist aesthetic and exceptional performance with AI-driven features and intuitive functionality. This new wave of appliances comprises the LG SIGNATURE French Door Refrigerator with T-OLED door panel, LG SIGNATURE Smart InstaView Over-the-Range Microwave and Slide-in Double Oven Induction Range, LG SIGNATURE Dishwasher, LG SIGNATURE Washer & Dryer and the LG SIGNATURE Washing Machine and Dryer pair.
Taste Beyond: Redefining the Kitchen
The 36-inch Smart InstaView French Door Refrigerator offers a differentiated kitchen experience with its remarkable and fully transparent T-OLED display embedded in the upper right door. This dual-purpose display serves as both a digital touch interface and a Dual InstaView panel, allowing users to conveniently manage the refrigerator and view its contents without opening the door. It can also display mesmerizing hologram-like visuals, blending the virtual with the real in a sublime fusion of art and high technology. For added ambiance, the refrigerator provides access to a curated music playlist* that lets users enjoy smooth, atmospheric beats whenever they are in the kitchen.
The refrigerator’s ThinQ Food management system and a built-in AI camera elevate convenience, automatically recognizing stored food items, suggesting recipes based on available ingredients and user preferences, and tracking inventory and expiration dates. These innovations streamline food management, menu planning and meal preparation, saving users time and making the kitchen a truly connected and dynamic space.
The LG SIGNATURE Over-the-Range Microwave and Slide-in Double Oven Induction Range enhance the culinary experience with their versatile cooking capabilities. The microwave is equipped with three built-in cameras for real-time cooking monitoring and time-lapse creation, capturing meals’ journeys from the oven to the table. The induction range, powered by Gourmet AI technology, identifies ingredients and provides helpful recipe suggestions.
The new LG SIGNATURE microwave not only excels in cooking and reheating but also redefines its category by delivering an immersive entertainment experience right in the kitchen. Featuring a 27-inch Full-HD touchscreen display with InstaView, built-in speakers and Wi-Fi connectivity, it enablesenjoy a variety of entertainment content while they cook. The screen also provides access to the LG ThinQ Smart Home Dashboard, allowing users to control all LG AI appliances and compatible Matter and Thread devices in the home. In addition, when paired with the induction range, the microwave’s LCD display conveniently shows the cooking progress of dishes in the range, eliminating the need to bend down and check the oven manually.
The LG SIGNATURE Dishwasher is designed to fit perfectly with existing cabinetry, creating a clean, built-in look for a sleek, modern kitchen. Its innovative pop-out handle sits flush with the door when not in use and automatically “pops out” when a hand approaches. The new dishwasher is equipped with LG’s exclusive and highly-efficient QuadWash Pro and Dynamic Heat Dry technologies.
Live Beyond: Seamless Laundry Solutions
The second-generation LG SIGNATURE lineup also offers exceptional advancements in laundry care. Featuring the LG SIGNATURE Washer & Dryer and 29-inch LG SIGNATURE Washing Machine and Dryer pair, the new laundry lineup leverages LG’s Artificial Intelligence Direct Drive (AI DD) 2.0 for precise fabric care, and inverter heat pump technology for effective, low-temperature drying. Each models is equipped with a 7-inch LCD touchscreen for easy control.
The LG SIGNATURE zone at CES 2025 will feature an “ideal lifestyle” space highlighting the second-generation lineup in settings like a living room, laundry room and kitchen. In collaboration with premium Italian furniture brand Molteni&C, LG will pair its technologically-advanced products with Molteni&C’s exquisite designs. Visitors will also experience the LG ThinQ ON AI home hub in action, demonstrating the ease and efficiency of the AI Home lifestyle.
“The expanded second-gen LG SIGNATURE lineup seamlessly combines advanced technology with elegant, modern design to deliver a smarter, more efficient luxury home lifestyle,” said Lyu Jae-cheol, president of the LG Home Appliance Solution Company. “Through the flawless fusion of state-of-the-art smart home, AI and connectivity technologies, we will continue to provide transformative customer experiences that go beyond expectations.”
Visitors to CES 2025 from January 7-10 can explore the new additions to the second-generation LG SIGNATURE lineup at LG’s booth (#15004, Las Vegas Convention Center).
* LG SIGNATURE refrigerator and LG SIGNATURE Over-the-Range microwave come with the “essential;” app pre-installed. essential; is a music curation brand operated by NHN Bugs, a South Korean music streaming service.
Equipped With Cutting-Edge AI Technologies, the Company’s Large-Capacity
Commercial Washers and Dryers Deliver Excellent Energy Efficiency
SEOUL, Nov. 7, 2024 — LG Electronics (LG) is showcasing its PROFESSIONAL LAUNDRY lineup at Texcare International 2024, a global B2B laundry and textile care exhibition, held in Frankfurt, Germany, from November 6-9. Prioritizing energy efficiency, the new lineup features a variety of large-capacity solutions, including 30-kilogram washers and dryers, as well as a washer-dryer combo with heat pump, offering a maximum capacity of 25 kilograms for washing and 16 kilograms for drying. With the launch of its PROFESSIONAL LAUNDRY lineup, LG aims to strengthen its position in the commercial laundry market, both in Europe and worldwide.
LG’s comprehensive range of large-capacity commercial washers and dryers provides several outstanding options for customers to choose from. The new PROFESSIONAL LAUNDRY lineup features 20-, 25- and 30-kilogram washers, as well as 25- and 30-kilogram dryers, along with a 25- kilogram washer-dryer combo. These solutions are equipped with LG’s advanced AI technology, which automatically adjusts water usage and washing/drying times based on load size, enabling a complete cycle in just 60 minutes.*
Along with energy efficiency, LG’s PROFESSIONAL LAUNDRY lineup boasts outstanding durability. The new washers feature the company’s Ball Balancing System, which supports a maximum spin speed of 1,100 RPM and enhances stability during high-speed washing cycles. The 25-kilogram washer-dryer combo stands out as one of the largest models in the heat pump combo category and is the industry’s first commercial combo to employ an inverter heat pump drying module. This proprietary technology significantly reduces drying times and boosts energy efficiency. Ideal for businesses with high laundry demands, such as hotels and care facilities, LG’s impressive heat pump combo represents a reliable, energy-efficient alternative to traditional gas and electric dryers.
LG’s commercial laundry solutions deliver further value with Proactive Customer Care, a smart service that actively monitors the machines’ operational data to identify potential issues before they arise. This service sends alerts to facility managers through the LG Laundry Crew app, allowing them to take preventive measures and avoid any service interruptions. In addition, the machines are equipped with features designed to safeguard performance, such as Tub Cleaning, which helps maintain hygienic conditions within the drum.
Since entering the global commercial laundry market in 2008, LG has consistently expanded its influence within the segment. Earlier this year, the company strengthened its partnership with WASH, a leading North American laundry service provider, to increase its presence in the growing U.S. and Canadian markets for laundry solutions in multi-family housing and university dormitories. LG also continues to showcase its innovations globally, with a successful appearance at the Clean Show 2022 in the U.S. and now at Texcare International 2024 in Germany.
With its new PROFESSIONAL lineup leading the way, LG plans to continue expanding its presence in Europe’s commercial laundry solutions sector. The company’s high-efficiency washer and dryer technologies will play a key role in helping commercial laundry operations lower their energy consumption.
“Building on our success in the residential washer and dryer market, we are now accelerating our efforts to lead the commercial laundry sector and are excited to launch our innovative, energy-efficient PROFESSIONAL LAUNDRY lineup,” said Lyu Jae-cheol, president of LG Electronics Home Appliance & Air Solution Company. “Texcare International 2024 is a notable opportunity to grow our commercial laundry business and strengthen our standing in the global market, particularly in Europe.”
* Based on an IEC standard load of 7 kilograms for washing and drying courses. Actual results may vary depending on usage environment and washing conditions.
Company’s Latest Appliances for the European Market Deliver Outstanding
Performance With Impressive Energy Savings
SEOUL, Sep. 2 2024 — At IFA 2024, LG Electronics (LG) is set to unveil its latest lineup of home appliances boasting industry-leading energy efficiency. Designed in response to the European Union’s ongoing efforts to achieve carbon neutrality by 2050, and aligned with the REPowerEU plan to reduce EU member countries’ dependency on fossil fuels, the new appliances leverage LG’s advanced core technologies to provide superb performance with reduced power consumption.
Industry-Leading Energy Efficiency with AI-Enhanced Laundry Solutions
LG’s latest washing machine and dryer set new standards for energy efficiency. The washing machine is able to perform a new drum motion that helps deliver clean laundry while minimizing the energy consumption of its Artificial Intelligence Direct Drive (AI DD) motor. The washer intelligently adjusts the motor’s RPM in real-time, contributing to the appliance’s impressive A-55 percent energy rating1 and preventing laundry from tangling or twisting. Additionally, LG’s new washing machine comes with a Microplastic Care cycle that reduces the shedding of microplastics from laundry,2 as well as the ezDispense feature, which automatically dispenses the right amount of detergent for each load.
Meanwhile, the efficient, new dryer has an A+++-26 percent energy rating.3 Both of LG’s latest laundry appliances are equipped with AI-driven innovations; the washing machine’s AI DD motor and AI Wash feature offer enhanced fabric-sensing capabilities and strong performance, while the dryer’s AI Dry provides accurate moisture detection and optimal drying for a range of different materials and laundry items. The washing machine can also automatically set cycle and temperature options based on usage patterns and change the order in which cycles are displayed on the control panel (according to usage-frequency) for a more convenient user experience.
Refrigerators with High Efficiency and Premium Design
Offering the lowest energy consumption of any refrigerator currently on the market, the new LG bottom-freezer refrigerator has an A-25 percent energy rating4 and brings style to the kitchen with its premium flat door design. In addition, the new model generates only 29dB during operation for a more peaceful kitchen environment. To give European customers greater choice, LG is expanding its line of highly efficient refrigerators, introducing a large capacity side-by-side model5 in addition to the new bottom-freezer. The new side-by-side refrigerator offers convenient features, such as the company’s unique Craft Ice spherical-ice maker, and easy hygiene management with UVnano technology.
Convenient and Efficient Kitchen Solution
Along with A++ energy efficiency,6 LG’s new 60-centimeter (24-inch) built-in InstaView oven presents a variety of cutting-edge features and AI technologies to elevate the culinary experience. The oven provides a total of 80 Auto Cook modes, and, with Gourmet AI, can identify the dish being cooked through its built-in camera, and automatically select the appropriate cooking mode from a database of 30 recipes. Making life in the kitchen that much easier, LG’s InstaView technology lets users check on their meal’s progress without even having to open the door, helping to preserve the temperature inside the oven and prevent energy waste.
Incorporating the company’s power-saving Inverter Direct Drive Motor, the new LG QuadWash dishwasher has an energy efficiency rating of A-20 percent.7 The dishwasher also enhances convenience with its Side Rack and 3rd Rack options, offering users the loading flexibility to accommodate a variety of different kitchenware.
“LG’s latest appliances meet growing European demand for energy efficient home solutions while simultaneously delivering superior performance and a more convenient life,” said Lyu Jae-cheol, president of LG Electronics Home Appliance & Air Solution Company. “We will continue to leverage our advanced core technologies, including inverter and component solutions, to deliver an expanded lineup of appliances with industry-leading energy efficiency.”
Visitors to LG’s booth (Hall 18, Messe Berlin) at IFA 2024 from September 6-10 can explore the company’s latest high-efficiency products for a more sustainable life.
1 55 percent lower than to the minimum threshold of energy efficiency class A in the Energy Efficiency Index, as defined by EU Regulation 2019/2014.
2 Tested by Intertek in July 2023. Comparing the Microplastic Care cycle and Mixed Fabric cycle of model F4Y7EYPBW by measuring the amount of microplastics filtered through a 20㎛ filter when washing a 3kg of load (100 percent polyester training jacket). Results may differ depending on the clothing washed and the usage environment.
3 26 percent lower than the minimum threshold of energy efficiency class A+++ in the Energy Efficiency Index, as defined by EU Regulation 392/2012, when set to Eco program.
4 25 percent lower than the minimum threshold for the A energy efficiency class in the Energy Efficiency Index, according to EU Regulation 2019/2016.
5 GSLE91EVAB is the European market’s first energy B-grade model within the category of side-by-side refrigerators with ice and water dispensers, based on Gfk market data from 13 EU countries, as of August 2024.
6 Based on energy efficiency tests on household electric cooking appliances, conducted in accordance with International Electrotechnical Commission (IEC) 60350-1 standard and energy efficiency class and index according to EU Regulation 65/2014. LG InstaView Oven’s energy consumption per cycle is 0.51kWh when set to fan-forced convection mode.
7 Based on household dishwasher Energy Efficiency Index according to EU Regulation 2019/2017. LG’s new dishwasher offers 20 percent more efficiency than an A-rated dishwasher model.
Alex
SEOUL, KOREA - LG Electronics (LG) today introduced its 2014 TV lineup in Korea, unveiling a total of 68 new models including ULTRA HD TVs in sizes ranging from 49 to 105 inches, its largest collection to date.
Among its new models is LG’s groundbreaking 105-inch Curved ULTRA HD TV in addition to its smaller 65-, 55- and 49-inch curved 4K units. As the first manufacturer to introduce an 84-inch ULTRA HD TV to the world in 2012, LG has consistently upped the ante with first-to-market ULTRA HD and OLED units. New for 2014 is LG’s webOS Smart TV platform, first unveiled at the Consumer Electronics Show in early January, which the company expects to set a new standard in the smart TV market for its openness and ease-of-use.
“We are extremely confident that our state-of-the-art ULTRA HD and OLED TV models will establish a new benchmark this year,” said Hyun-hwoi Ha, president and CEO of the LG Electronics Home Entertainment Company. “With our strong competitiveness in display technology including ULTRA IPS, CINEMA 3D and the unrivalled simplicity of the webOS Smart TV platform, we are optimistic that in 2014, LG will be the one to watch in the TV industry.”
Sent from my iPhone using Tapatalk 2
4 answers to this question
