    • By netsplit
    • By svsrama
      Sriram.
    • By tim p
      I have two LG C2 tv's both running OS 03.21.30. Attempts to update the OS state that this is the current version as of 12/2022.  Amazon Music won't open on either of them, the splash screen appears and that's it, for hours.  It opens fine on other devices in the house, Sony TV, PC's, and droid phones. Other streaming apps work fine with no buffering or glitches.
      The solutions offered online list instructions for clearing app caches using a series of menus that aren't even remotely close to the menus available on these TV's.  I've checked every available menu and there's absolutely nothing offering the ability to clear app caches. App Manager offers exactly two options: Launch or Delete. Others insist that you need to clear the cache from within the app but of course the app won't open so that's a dead end.  I did clear the browser cache but it had no effect this AMZN Music problem.
      So far I've also:
      Deleted and re-installed the app multiple times; Left the TV's unplugged 24+ hours; Full reboot of the router multiple times; Factory Reset of the TV's. If anyone has a solution that doesn't involve buying a fire stick I'm very interested - thanks
      (edit) one of these tv's is five feet from the router.  Distance isn't the issue.
    • By Nitin Chopra
      Hi Team,
      After update of LG WebOS to 04.40.70, Amazon Prime Video app on my LG Smart TV stopped working. It started giving error :
      Internet Connectivity Problem
      There is an internet connection problem. Check the device's internet settings, data cables, or try to resetting your router. Also, turning your device off, and then back on might fix the problem. For further assistance, please contact Amazon customer service at www.amazon.com/videohelp
      The internet/wifi connection is fine and all the other apps are working without any issue on the LG smart TV.
      I have even tried uninstalling and reinstalling the Prime video app, but that didn't help.
      Has anyone faced this issue ? Is there a solution available for this issue.
      Thanks & Regards,
      Nitin
    • By Bella Lee
      With the Amazon Music app, LG smart TV owners who also happen to be Prime members can finally access two million songs on their TVs. But there is a more convenient approach for you to play Amazon Music on LG smart TV. With an link hidden, please login to view or Mac, you are able to and them play them directly on your smart TV without the Amazon Music app. And you don't worry that your smart TV is not compatible with LG smart TV.
