webOS - Greek Subtitle enconding issue
By SHawk
By Regis Wheeler
By JasonB
By Bella Lee
link hidden, please login to view. With Tunelf Spotibeat Music Converter, you can and then transfer them to LG webOS Smartwatch for playing without limits. -
By Gabriel Śmiech
smioannou
Greek subtitles are not displayed correctly, greek encoding is not supported yet for LG 42LB650V fw 03.23.08 webos 1.2.0-2708
3 answers to this question
