Ima li netko iskustva sa snimanjem (PVR) preko programiranja (EPG) s webos na LG LB671V  modelima ?
Je li snimljeni film imenovam prema imenu iz EPG-a ili prema nazivu programu i trenutku početka snimanja ?
Može li se snimljeni film:
a) preinemenovati
B) premjestiti u drugu mapu
3) može li se staviti RO atribut na film ?
Does anyone have experience with recording (PVR) through programming (EPG) with webOS on LG LB671V models?
Is the film a title recorded by name from the EPG or by the name of the program and the moment you start recording?
Can a movie which was recorded:
a) change the name
B) move to another folder
c) can you put the Read Only attribute to the movie?
    • By Bhanu Kumar
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
