NO doubt, even the basic user needs some more refined DLNA client, and possibly a client that directly reads on shares, like Plex clients used to do.....
Issues to be solved are basically four:
- Media structure
- Metadata presentation
- Multiple Audio Tracks choice
- Subtitles
Any idea?
I for one would also really love to have a working plex app for my lg webos tv.
Right now via dlna I can't get (auto downloaded by plex media server) subtitles, I can't resume where I last stopped viewing and I can't see which episodes I already viewed.
For those reasons I really wish to have a plexx app real fast. Also, plex interface is a lot nicer with album covers and fanart and imdb movie information etc.
  • 2 weeks later...
I currently run a plex media server on my ZyXEL NSA 310. Previously I have used an RasPlex installed on a Raspberry Pi, but it was to slow.
Fyi i am currently working a port of my app plex for lg home theater ... Plex.sithari.com.au
  • 2 weeks later...
  • 2 weeks later...
Yes, a proper Plex app will be nice.
In the meantime, you can use the browser to browse to your Plex server and get the Plex web app. It's a little slow to browse but otherwise works fine.
Or, what I have done, is to get a Chromecast. Now I can browse Plex on my iPad or Android phone and cast to the TV. It works for YouTube too, allowing a better YouTube browsing experience than the TV's app has.
.... many people have reported getting my native plex client working on webOS, check the forum link ... should be in the app store soon ...
simonjhogan
I got it working but found it a little slow, much like accessing the Plex server through the browser. I assumed that would be improved once the release version of the app was available.
  • 2 weeks later...
I have an apple TV. Can i stream from my iPad using the plex app to my TV?
Some of my movie files are on MKV particularly the 3D titles.
Just bought a LG 47LB730V, Brilliant except no Plex app to be seen to my disappointed, out of all the apps, I realy thought that there would be a Plex App Available,
however I am using my Roku 3 connected to it for plex and it runs smoothly, Would like the Plex Smart App though.
  • 2 weeks later...
  • 1 month later...
There is a PLAYz Media app that is a PLEX client in the LG store for my TV, (The LG- 55UB8500 55" 4K TV) I would figure it is not specific to my TV but the overall store.  I didn't try it yet, has anyone been playing with it?
  • 2 weeks later...
  • 4 weeks later...
  • 3 months later...
Yes, I paid for the PLAYz app and use it almost daily. For me it is money well spend.
Subtitles work without problems. If subtitles are available you can turn them on or off, or select which subtitle you want if there is more than one.
I found that changing or selecting subtitle does not work very well from the screen right before you play something. It works best, and without any problems, while playing something by opening the subtitle menu while your movie is playing, so not by going back, but while playing press OK, go to the right and select the speech balloon icon on bottom right of your screen.
    • By DavidSr
    • By Lgrump
      Is it just me or is the plex app just unusable on webos.  When I try to select dvr items with the magic remote they just don’t play.  I am not sure if this is a plex issue or an lg webos issue.  Anyone know which it is?
    • By Xuancong Wang
      I have two LG TVs, 65SM8600PTA and OLED48A1PTA respectively. Both are connected to the same NAS router via LAN cable. Both can enter the NAS folder containing my Chinese drama series collection.
      65SM8600PTA can play everything smoothly. OLED48A1PTA always stucks at loading the drama series folder (which contains ~60 video files, each video is in the size range 400MB-2GB) for very long time, >3 minutes. Upon clicking into the last layer folder, the spinner spins for very long time while attempting to regenerate previews for this and parent folders. So if there is an option to skip generating video/image previews, then listing folder content can complete much faster, and then that will solve the problem.
      I would like request this additional option for OLED48A1PTA to skip generating preview so that NAS video list can show up quickly.
      OLED48A1PTA is bought from Shopee recently under 15-day-free-return policy, if you can push an update before 2022-02-10 that solves this problem, I will accept the product. Otherwise I will raise a return-and-refund request because the OLED screen also has vertical strip issue when displaying grey background.
      Thanks for your notification!
    • By Jason Worthen
      I need to set my plex app settings to allow insecure connections. and I have tried everything to find a menu to the plex app settings. But I cant seam to find a way there.
    • Solution For That Pollution
    • By Denneke
      I have installed the Plex app op my CX65 but I can not reach my synology nas via smb. I have an older synology version which isnt able to transcode, so i want to use the tv for transcoding.
      Is it possible to access my synology via smb with the plex app? How can i do this? Is it necassary to install media server on my synology?
      Thank you.
