Well, I can't setup the broadcast country on Brazil, my TV set is designed for EU. But I set it up for UK and found the Plex app. But, since I'm not a Plex pass subscriber, it doesn't help me.
Ive been using the Playz App (third part plex app) for months.  Simon the developer has managed to include all the functions but unfortunately it is really slow. the device connector built-in in WebOS is faster.  By slow i mean the playz app struggles with files with a 3GB size and larger hence video shutters/ stops (buffers). the same videos play well with device connect. color rendition is off too but can be corrected by assigning a color profile to compensate. there are other issues too but until plex decides to create a NATIVE app Playz is the only game in town other than the device connect feature of the your webos tv.
Just an fyi the video issues has nothing to do with PLAYz ... It is an issue with the web api and video player ... The dlna player doesn't use the web api ...
Sent from my iPhone using Tapatalk
There's an official Plex app in the LG Store. I have just installed it and it's working fine. It's a great app:
Do you need a Plex account to use it?
You can download the official Plex app from the LG Store. Try to search it. It doesn't appear in the main page but if you write "plex" in the search bar, the two apps will appear (this offcial one and the PlayZ).
Alex app in LG TV is called Playz, not Plex. Play works fine. I use it every day. I have Plex Media Server on a Qnap NAS and I see movies and TV shows on my LG.
  • 2 years later...
Can you help me?! I am from Azerbaijan.I have LG Tv 43LF631V.And in my Tv don't work Lg content store.I didn't enter any apps.I try to reset my tv from the settings menu.But don't change any.I know to enter service menu (EZ adjust) whit a smartphone.But I don't know codes( area, country, tools)in the service menu.If you know codes, send me, please
  • 5 months later...
    • By DavidSr
    • By Lgrump
      Is it just me or is the plex app just unusable on webos.  When I try to select dvr items with the magic remote they just don’t play.  I am not sure if this is a plex issue or an lg webos issue.  Anyone know which it is?
    • By Xuancong Wang
      I have two LG TVs, 65SM8600PTA and OLED48A1PTA respectively. Both are connected to the same NAS router via LAN cable. Both can enter the NAS folder containing my Chinese drama series collection.
      65SM8600PTA can play everything smoothly. OLED48A1PTA always stucks at loading the drama series folder (which contains ~60 video files, each video is in the size range 400MB-2GB) for very long time, >3 minutes. Upon clicking into the last layer folder, the spinner spins for very long time while attempting to regenerate previews for this and parent folders. So if there is an option to skip generating video/image previews, then listing folder content can complete much faster, and then that will solve the problem.
      I would like request this additional option for OLED48A1PTA to skip generating preview so that NAS video list can show up quickly.
      OLED48A1PTA is bought from Shopee recently under 15-day-free-return policy, if you can push an update before 2022-02-10 that solves this problem, I will accept the product. Otherwise I will raise a return-and-refund request because the OLED screen also has vertical strip issue when displaying grey background.
      Thanks for your notification!
    • By Jason Worthen
      I need to set my plex app settings to allow insecure connections. and I have tried everything to find a menu to the plex app settings. But I cant seam to find a way there.
    • Solution For That Pollution
    • By Denneke
      I have installed the Plex app op my CX65 but I can not reach my synology nas via smb. I have an older synology version which isnt able to transcode, so i want to use the tv for transcoding.
      Is it possible to access my synology via smb with the plex app? How can i do this? Is it necassary to install media server on my synology?
      Thank you.
