Hi guys,
I'm testing a basic app using the CLI but got the following error when trying to package my project:
$ ares-package .
ares-package ERR! ares-package: Error: rsync exited with code 23
Any ideas?
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By geoffHome
      Reset our router (turn off then turned on again  and waited) but now no networks are even found to attempt to connect to.
      Any suggestions what my next step should be?  This has happened suddenly.  Thanks
