Questions about the new WebOs TV
By Khelben Arunsun
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By The Old Man
Hey LG
Yes I am NOT happy
By tarakdave
MrNorth
Hi!
New member from Sweden here, long time .NET developer and HTPC/WIndows Media Center buff...
I tested this new TV at a friend of mine, and I was fairly impressed with the new design and concept of these new "smart tvs". However, the experience did raise a few questions, that I am hoping someone can answer before I actually purchase one for our family.
1) How do I record an entire series of a tv show? In WMC (WIndows Media Center) I just select the program in the epg and either press the rec button fast twice or press info->Record series. A must have for our family, since we watch a lot of DVB-T TV. Streaming services are not that evolved here in sweden.
2) After scheduled a recording, the TV wakes itself up and perform the record in the "background" even if no one is using it? What happens if the TV is in use at the time of the scheduled recording? Does the TV ask the user to confirm channel change?
3) Any way to get to the guide fast (rather by a single remote press) from anywhere by using the magic remote?
4) Does the browser support flash/html5? Most online content in Sweden from the major networks use flash and none have apps for the webos tv. Watching in the browser could work if it supports flash?
5) Any way to pin bookmarks on the start menu? (I know this has been asked before but no answer)
6) WITFM? In the IT world, we often use the phrase "read the f-cking manual" (RTFM) but in this case I ask "where is the f-cking manual"? The printed stuff and the electronic manual are both extremly basic. The LG website contains only lots of marketing bla bla... is there ANY kind of user manual out there?
7) Is it possible to know the expected lifetime for a2014 TV with webos? If I buy a smartphone (Like an IPhone or Windows Phone) they release updates and feature packs at a regular basis, how is this done with the LG web os TV? Is there a developer blog or something where the users get info on version x.x of the web-os? As of now, there seems to be lots of confusion even about what the firmware updates contain... Not much transparency from LG?
8) What about missing features and stuff like that? Any way to know what LG has in mind for the LG web os in the upcoming months or year? It feels there are lots of essential features missing, would be good to know what is in the pipeline... Even big companies like Microsoft can communicate with their "fans" through twitter and blogs, I am sure that LG can too...
9) Are there any other magic remotes than this one? I feel it lack some "must have" keys, and I would LOVE to get rid of the 3D button that someone figured was important enough to earn a place on the remote...
cheers!
Henrik
24 answers to this question
