20 answers to this question
Call LG support. It is not normal. They should send an engineer to check what is going on. Also, perform a factory reset and try again. I know it is cumbersome because you will have to redo all picture settings but it is worth a try.
It works! i did factor reset and everything works  :) - note: memory size = 4.2GB
Could you please share where you came across this info (4.2 GB memory size) ???
Can you attach an external HDMI Hard Drive to extend the storage capacity on a LG Smart TV? I have a 49UB8500? I have a 500GB HDD that I currently have connected to my HD DVR for extra storage.
I've just purchased the Skylanders battlegrounds pack for My new LG 42LB730 and according to the TV I have 973MB of space and the game needs 1062MB. I've tried to use a USB stick for extra storage but I can't get the TV to use it for that. How can I use this version of the game developed to work specially with the WebOS system when the TV itself can't take it? I've tried the factory reset and it's up to date on the firmware.
It's not 4.2 GB, it's wrong information, the size is 1GB, you can know this by lg customer support or by going to lg store in the tv and trying to install a app, it will show you the memory below the instalation status.
  • Thanks 1
No,the memory issue is happening to everyone who has a Lg TV running the WebOS, it is caused by an unprofessional programming that leads to a memory leakage, as you can compare to their old OS Netcast, you could watch everithing on the web browser and it even had flash player, lg is going backwards because their new OS the WebOS, so called the fastest TV OS by LG is a shit for me, i bought lg TV because i wanted to watch movies in the web browser but it doesn't do what it's pourpose is, if you only want to watch youtube and use facebook, you can buy a BluRay player wich supports it, don't buy a LG smart TV.
  • Thanks 1
I have the same problem - new LG TV cannot install Skylanders: Battlegrounds (bundled with the TV, OMG!) due to low space.
How can I solve it? Factory reset did not help.
OMG I have the exact same problem! I bought the 47LB731V lg tv and it came with the Skylanders battlegrounds. I tried to download it and there wasn't enough space. I put a usb memory stick and when the download finished it gave me an error message. I have tried three different usb sticks and hdds and it always shows the same error! Does anyone know how do I fix it?
To fix the problem with all smart tvs is for the factory to install at least 64 G of ram on all tvs as with my phone  i have 64 g of ram and it still could use more but that would be to smart for them
i can not see why the cost would be the issue ram is cheep now a days ,Next time you buy a smart tv ask how much ram it has if it dont have 64 g and it wont dont buy it  they will shortly fix the issue  1 g is just a toy.
I got a android pad w 8 gig of ram toy junk i got a android 16 g ram better still ran out of memory then a android with 32 g works rely good 64 g would be best for most devices   Get Smart ask before you buy I do now .a smart tv should be smart not to cheep .
Anyone Want to buy my 50 in 4k LG tv or trade for a non smart tv ?
Why not use you LG as a non smart tv? Buy a chromecast/apple tv/fire stick or whatever you like and install all your apps on it.
    • By RJ Fischer
    • By mycop
      Greetings.
    • By Regis Wheeler
    • By JasonB
    • By AMK
      Tv model 55UJ630V-TA
      Sw version 06.10.50
