Can an app be automatically started when TV is turned on?
is it possible to develop an app that is automatically started once the TV is turned on?
It would be similar to a "kiosk" or "hotel" mode. The reason is that the TV shall be used
to display infos to customers. In unexpected cases like failure of elelctricity the TV
will boot and the app should be started automatically, so that the infos are
displayed again without user interaction.
I'm not sure where to start looking how this can be achieved.
Any suggestions?
Thanks!
-Carsten
    • By JamesH
    • By starwoodtech
    • By bos2prov
    • By Jibun no Kage
      Brand new LG TV (WebOS 8x) WILL NOT stay off when turned off with the remote?  Out of the box, connected to internet, seems to have been updated, and working fine.  But when I hit the power off with the remote, the TV reports 'Life is Good' seems to turn off, i.e. go into standby, and then a few seconds later, turns back on.  If the device connected to the TV on the last active HDMI port is OFF, I get the No Signal warning.  So I know the active HDMI input is not generating any signal.  I want to believe that any other device on any other HDMI port might be an issue? But then the TV would switch to that HDMI port, no?  This is really an issue!  If I use the phone app I can turn off the TV and it seems to stay off, at least does not come back on in a few seconds like the remote?  If I send 'standby' via HDMI-CEC, that seems to work as well, the TV seems to stay in standby mode.  This a bug?
    • By Jibun no Kage
      Asking this hear, since I could not seem to find a better place... Wake on LAN only works for a few minutes after TV is turned off?  If I turn of LG TV (WebOS 8.x) and then send a Wake on LAN (WoL) packet, it works.  If turn off the LG TV, then I wait about 15 minutes or so, then send the same WoL sequence, using the same code, script, etc., it fails, the LG TV never turns on.  THe LG TV is configured both for wired ethernet (preferred) and WiFi.  Any idea why this behavior?  It almost seems like the LG TV goes into standby, via phone app, remote, even CEC, etc., then drops from the network?  Mobile is enabled on the TV, hence the phone app works.  Why would the LG TV stop responding to WoL packets?
