Having had a few weeks to adjust to the 50LB6500 the slowness of the interface at startup and when pulling down the TV Guide is very frustrating. A single tuner in this model is a serious obstacle to usability. When you first turn on a TV the thing you most want to access is the guide, and you have to wait ages just to get the WebOS interface running, then wait even longer to see anything useful on the TV Guide.
One thing that would make the TV Guide more useful is a function to scan through the channels and grab the broadcast information. The current implementation of the App makes you do this manually. That's not really a Smart TV, it's a Lazy TV. Can't you do better with the guide LG?
E
  • 2 weeks later...
Do you mean the guide is pulled down EVERY time the tv launches? That's crazy, why not have a small local DB where you store the guide data (where does it come from anyway, is it embedded or from LG locally?) and then update it like every night? I can really understand that it is slow if it has to load all guide data every single time you start the TV.
I am also running Windows Media Center here at home, and there you can have combined guide data, e.g. where no guide data exists from the XML feed from Microsoft, the app is getting the guide data from the DVB-T feed itself, and that is SLOW. Takes about 10 seconds or something.
Most sett op boxes also take the guide data from the DVB-stream, and I have never experienced them being so slow... I wonder what the problem is with WebOS?
Do report this to LG!
/H
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By RussS
      Russell
    • By Den C
    • Solution For That Pollution
    • By tezz7624
      re tv guide
      used to be arrows to allow viewing of previous programs on catch up but they seemed to have disappeared
      is there a way to make them return
