Bookmark locations on a DLNA server
By Lorenz
By delos
Hey everyone,
I'm new here, so first of all, hello I'm delos.
I own two LG OLED55G19 TVs, one at home and one elsewhere. At home, I have a QNAP NAS (TS451) with DLNA functionality. Accessing it at home works great.
The "Home" and "External" networks are connected via VPN. Thus, both networks have different network addresses.
Now I want to access the home network from the external network with the LG via VPN in order to integrate the DLNA server. The LG doesn't "see" the external server because it's not in the same network. However, I wonder why you can't just enter the IP address of the server in the LG.
Does anyone have a solution?
Many greetings
delos
By Muser
By Nick Payne
By Kuriko
Hey, I have 3 NAS (DLNA) successfully connected to my OLED65C97LA since months and from one day to another all three have the same issue. So I must be a bug in LG TV? But I do not know what to do?
- I can click on all 3 DLNA and its open a choice box for "music" or "image and video".
- Click on all 3 DLNA for "music" and I get access to this DLNA and see my music files and can play it.
- Click on all 3 DLNA für "image and video" and I get now only a black screen. I can move the cursor and open menus, but DLNA is black.
Am I the only one with this problem?
- 1 answer
- 3,694 views
- 0 replies
- 1,873 views
- 12 answers
- 104,590 views
- 1 answer
- 7,067 views
