LB731 webOS - problem with subtitle encoding and mkv files
By Venkata
Hello Team,
By Roy Brown
By Khelben Arunsun
By PVD
By magicschooldropout9
BrUtAlls
I got few MKV files where i cant change subtitle encoding (when i change encoding nothing happens). Other settings work fine (size, color, position).
Im using Smartshare.
Software Version: 03.23.24
webOS TV Version: 1.2.0-2724
MKV files where changing subtitle encoding doesn't work:
MKV files that work fine:
I did test one subtitle on both MKV files, and on one subtitle encoding works, on another MKV i cant change encoding.
Did try serviio and direct over USB HD.
How to fix this? I really want to play my movies and have normal subtitles.... Thanks
4 answers to this question
