Just an update: I've received a straight answer from LG support, that there wil be no WebOS 2.0 via Update for the 2014 models, and generally for models running older WebOS... (well, who knows if that's really true for all those models, because of the other official press statements saying otherwise -for higher models/series).
Anyhow, I'm no longer concerned ... decided to rather go with Panasonic TX-48AX630 (and I'm absolutely happy with it). Bye
I have different news about webOS 2.0  :P
  • Download Software_File(Version_04.51.49).zip and unzip to HDD/SSD
Format usb flash drive in FAT32
Create folder LG_DTV on your usb flash drive (LG_DTV with _ )
Copy starfish-atsc-secured-goldfinger-38.arches-3849-04.51.49-prodkey_usb_V3_SECURED.epk file into folder LG_DTV
Safely remove usb flash drive from PC
Connect usb flash drive to your TV USB port (any free port)
Wait message for update and confirm with remote controller
After sucessfuly update, reboot your TV (switch off/on)
Go to Settings and Reset to initial factory settings
Set your TV
Enjoy :rolleyes:
  • 2 weeks later...
04.45.25 42LB630 I have problem after update. TV random reboot when i change program.
Sent from my GT-I9195 using Tapatalk
i have same problem with my.LG 47LB650V with last two firmware updtes. changing chanel od exting apps tv reboots
Turn off HBB.
I only turn off HBB and solved problem.
hi whats HBB is it in settings,ive turned most things off in settings,and done a reset,still same.
  • 3 weeks later...
Hi I have a Spanish 32lb650v-zn model
The last version I found about a month ago was via auto update location UK it was
4.45.25 and webOS was 1.3.3.3251 (Afro-arches)
Today after trying lots of things I found a new version
4.65.05 and webOS 1.3.3.3253
It auto downloaded from South Africa
Started up good and so far no,problems
Regarding my last post. Having had a a quick play I can say the interface is much much faster. Almost instant very pleased and happy with this update David 4.62.50 downloaded by changing country to South Africa. Hope you find it as good as I have !
I confirm the update is available for download from South Africa.
Just installed (automatically) on LB650v, with no problems thanks for the tip davidisom.
For now I can't notice any changes.
The speed seems the same, maybe a little fast showing of the launcher. The setting still have to load for the first time.
The version is 4.65.05.
Update you are correct I typed version number wrong it is 04.65.05 as you say.
Sorry you did not notice speed improvement mine has been quite dramatic. Whether the factory reset makes a difference maybe ?
i havethe lb650v but can not find south africa in the drop down menu.
Just change location in general menu then go to about TV and then select check for update. TV will do the east for you David
tried changing to different country but then i got no update needed message, and had retune my tv again
The option to choose does not require re-tune the location is lg services country ! David
Spanish bought 42LB731V-ZE changed from UK to South Africa checked manualy for update and updated from 04.45.25 / 1.3.3-3521 to 04.65.05 / 1.3.3-3953, updated just fine. Once again the menus seem a bit snappier only played with it for an hour or so. Looking good to me. Keep em coming LG. I'm liking thos tv more now. Lets see how it pans out over time. Fingers crossed.
Jon T
thanks davidsum. just sorted it. do i have to do a reset after the update or doesent it matter,
No need normally to reset. But the odd person has said for them they did need to.
Glad you got it in the end. David
  • 4 weeks later...
Hi everybody
My TV set is set to south africa
you can download the new version from LG Global
here is the link
follow the procedure for USB upgrade
Good luck
Cheers Magdymans,
Had a quick look at the link on my phone, then I realised it was a dowload link for the firmware (haha) just used the last of my data allowance 690 mb. lol
Teach me to read more carefully.
Might not risk the usb update just yet. I'll wait to download from tv
Thanks anyway,
Jon
