Away from the TV for s few days but I think I posted the version I have a while ago.
Hi , found it , you are on 4.65.50 same as I was on previously and the screen remote did not work for me on that in NZ mode either . Strange as I dont think theres much difference between our TVs .
My TV 42LB6520-TB was bought from Dubai.
Updated to 4.65.05 long ago. Seems all countries received the ver. 5.XX variants.
But nothing here for me. Any clue?
N.B. Both broadcast & service country set as: South Africa
Sent from my Nexus 5 using Tapatalk
After 1h40m still no memory error on Pioneer HDMI/CEC Simplink, i hope it works now  ;)
Hi , Have you noticed any other improvements or changes ?
Nope, can't tell the diffience between 5.00.04 and this one. No memory error after 3h20m. But now it's time for bed. (I am happy now no more MEM error).
Good for you, Demonrider. This app will now restart to free up memory on my LG650V when I searched for something in Google.
I do not have any problems with other applications, only this shitty browser pissed me off every moment. I hope that you remain happy when you wake up.
BTW I think that they already do not fix it. We need more physical memory rather than seeking a miracle in the firmware.
5.00.15 No mem error simplink cec hdmi works OK
Rassbery pi one with openelec cec hdmi works super stable
Arc with dts dd5.1 works OK
Internet browser stable No mem error
Tv app No mem error after 6 hour work
Firmware looks ok
Firmware looks ok
And finally works UTF8 in the EPG :)
Ok, downloading as I type, I´m going to try this 05.00.15 software. My Raspberry Pi2 needs to be utilized a little more.
if all else fails I have not uninstalled the LG_updater so will be easy to downgrade, If not Dejan I´m coming after you. ;) for tempting me with your endless firmware supply's. :D
Cheers
Jon
I dont think the grass is any greener on the other side . I had the panasonic 60AS800 , so called flagship hd model for 2014 and it also had memory issues when using the webb browser , Dont think there installing  enough memory for the job .
I hope U R not justifying LG by writing Panasonic issue.
No not at all, I have had both and find it amazing that they both have the same errors that could possibly be avoided by more memory.
I upgrade my TV 47LB731V to 5.00.15 and all working fine. I'm using ARC. I have Pioneer 921 Amplituner connected through HDMI, since yesterday no "memory error". I had it every 15 minutes on 5.00.04
For some stupid reason I upgraded to the 5.00.15 update and have lost multi channel over Arc again :( should have just left it alone.
Can u double check your settings ? I have no problem with multi channel over ARC/HDMI. Did u reset to factory settings after upgrade ?
I did a factory reset twice, same results. Netflix, Plex, FTA TV, all two channel.
Can u go to Settings >> Sound >> Sound Out >> and check if "Digital Sound Out" is set to Auto ?
Can u go to Settings >> Sound >> and check if "DTV Audio Setting" is set to Auto ?
New *TEST* firmware version 05.00.20 for LB630-LB870, EC930 (Europe)
File size: 678,409,360 bytes
Change log:
• Bug fixes
• Speed improvement
Hi.
Are there no information about what the fixes fix?
\Lars
Can I confirm that nobody is having issues with Out of memory when ARC is enabled and they are simply watching a HDMI input using 05.00.15?
In addition can anyone confirm the above true for 05.00.20?
I already using 05.00.20 since today, totaly no issues with ARC. Also no issues with 05.00.15 (I used it for few days)
Switching channels are quicker as well.
Panasonic also... Nice.  :huh:
Totally agree. I don't understand that way. New TV, newest firmware and shit welcome again. My older LB5800 is still working perfectly. I think that's my last journey with fkng LG.
