Use this method to update the beta frimware ?
Yes..
In short line:
1. format usb flash stick to fat32
2. make folder LG_DTV
3. Copy .epk file to this folder
3. Safely remove usb flash from computer
4. connect usb flash stick to usb in tv (any usb)
5. when update message pop-up click to "Install" and wait about 5-10 minutes to final message about sucessful update popups again something like that in top right corner  "new software is installed and will be applied when next turn off/on tv.."
6. now you can turn off tv with remote controler and unplug usb flash
7. turn tv on and wait 1-3 minutes
8. youre updated :)
Dejan, you are the man. Thanks for the heads up.
Who wish to try something interesting, do as following:
1. Install "Accuweather" from market
2. Change dns to 85.17.30.89
3. Start "Accuweather"
4.  :)
Source:
4.  :)
Source:
What does this do? Sorry I dont read/speak russian.
K.
05.00.55 installed on 55ec930v. Best firmware so far for me. I have tried about 10 different firmwares last year. Tested for a few hours.
No memory leaks
No hdmi cec/simplink problems
No hdmi arc disconnects
No hdmi pop-ups
I did not test the browser because I don't use it.
Finally a decent firmware for me
No memory leaks
No hdmi pop-ups
I can also confirm that this firmware is a bit faster
Model: 55UB850V-ZD United Kingdom
F/W: 05.00.70
This still has ARC HDMI issues the sound just keeps dropping out every now and again!! Urgh!
Regards,
Robbie
Crazy..  :huh:
Tip: Did you reset the TV to factory initial settings after firmware upgrade?  :mellow:
    4.
    Source:
Useless. It installs fork player but is all russian. And its very buggy. Waste of time.
65LB7500
V 05.00.35
Australia
Having the same issues with the ARC dropping out.
Contacted LG and they are F***ing hopeless.
They want me to pay for a tech to come out to test the hardware.
But I don't think there is any problem with that.
And will not admit there is a fault in software.
Does any one know if .55 will work in Australia?
Or when LG plan to put out a Update?
Cheers
65LB7500
V 05.00.35
Australia
Cheers
65LB7500
V 05.00.35
Australia
Cheers
Hi, I ended up going through lgnz marketing folks via their Facebook page, they gave me a link to get the 55 download. I know the AU & NZ firmware has differences so no point sharing that but I'd suggest try through Facebook because you're right their sales support people are as useless as tits on a bull...
But if you want to risk it this is what they sent me, it has solved all the problems pre 55 I was also experiencing...
Here is the download link, you will need to place this file in a folder LG_DTV on a usb stick, and insert to the TV while left on an input.
Let us know how you get on.
Thanks Michael.
Why would AU and NZ be different?
I will give the facebook ago.
Thanks Shane.
Where did you get .55 from?
Cheers for your help.
Lg gave me that link via their Facebook page here in NZ. The settings are different for terrestrial tv I believe. It's worth a try I guess I imagine worst case you'll need to retune TVs setup stuff.
Thanks Michael.
Thanks Shane.
Thanks Michael.
Thanks Shane.
Thanks guys.
All loaded and working.
I will give it a few days and then I will call LG and give them a piece of my mind.
So unhappy with there help. My original email just asked when they where going to fix the software issue. But they seem to think it's a hardware fault.
At least I'm not alone.
Thanks again
