Hi, I have an LG UF776 with 4.25.10 OS version.
Do you know if exist an update official or beta?
There is new test/beta firmware 04.25.55 for UF680, UF770-UF778, EF950, EG920 (webOS 2) (Europe)
Source:
Hi Team
I have little problem. I stuck with 05.05.01.
When I click "Check update" then TV start switching chanels in the background and after few minutes says can't find any update..
I did yesterday FW downgrade using Simon procedure http://www.lgwebos.com/topic/1997-how-to-downgrade-webos-tv-firmware-tutorial/
then Tv start dowloading new FW's (couple versions) but again stuck with 05.05.01, and again start switching chanels and no update found..
My tv 47LB731V-ZE
Any idea?
p.s Yes I can use USB stick, but I need to know what happen with my TV first .. Please note that in the past I used Beta versions as well..
I think you should reset to factory settings and try if this problem appears then flash new beta. BTW there is another beta/test 05.05.35. Read my post here
I did factory reset each FW upgrade.. So seems this is not a solution.
Any other idea ?
Any other idea ?
Hm..interesting. For me, just disappear channel(black screen) while seeking new version, but only in LiveTV...not in HDMI. Maybe another beta flashing?
Model: UH610V
Firmware: 04.30.50
WebOS Version: Not sure where to find this information
Country: UK
This updated in the past week and now I am finding that my DivX media server can't often find it via DLNA(?), and if it is found, then in the 'Photos and Videos' app, the media server is often not shown no matter how many times I press refresh, exit/restart app or restart both my computer and TV.
Really annoying! Used to work fine before!
Having an LG 55LB870B on 05.05.01 firmware
compared to the previous one I noticed a worse image quality about TrueMotion, it is too noticeable! even after resetting TV settings (checked with the same movie I watched lot of times)
Does anyone else found the same issue?
I'm currently downloading 05.05.20 official from LG website, I'll report if the issue is fixed....
EDIT: installed 05.05.20 and the issue seems to be fixed! TV is a little quicker in menu too
Hi Team
My tv 47LB731V-ZE
Any idea?
Just thinking now maybe 05.05.20 is not available via TV update yet.
Maybe someone from Poland could confirm it?
Wysłane z iPhone za pomocą Tapatalk
I'm not in Poland but in Germany but I don't get any new version via Ota update too. Still on 05.05.01.
Regards,
K.
Ok so it's looks like we will have to wait..
BTW. Can someone confirm where 05.05.20 is avilable via OTA..
Just download 05.05.20 officially from LG site
Unzip "Software_File(Version_05.05.20).zip" , format usb flash stick to fat32, create folder LG_DTV and copy file "starfish-dvb-secured-m14tv-25.ashley.m14tv-2522-05.05.20-prodkey_nsu_V3_SECURED.epk" into this folder, safely remove usb, plug into TV and install...or wait a while LG prepared for us new firmware update 05.05.35 (now in test/beta)
The quick availability of the BETA .35 Update after .20 was just released is suspicious to me... as if .20 had a serious bug and needed instant fixing... not sure if I want to risk installing .20 via USB unless I see more reports from users having no problems with 05.05.20 ...
K.
Yes I will wait..
New official firmware 05.05.20
LB630-LB870 and EC930
Hello I'm from India and I've 47LB750T on official firmware 05.00.55. Can I install this 05.05.xx firmware on my TV? The only difference I see in the model version the end character, I've 'T' while the model you are mentioning has 'V'.
This is file for europe region, so answer is NO
i have an LG 49UB850V, with a firmware version 05.10.01 (it's a beta) and webOS version 1.4.0-2301 afro-ashley.
Do you know if there are more recent/stable version of my firmware?
I've just installed 05.05.20 on a 42LB731. As always seems a little snapier but I think the picture quality has improved or returned to pre 05.**.** version softwares. Will play around later.
Jonny did u installed this update via OTA or USB ?
Installed via usb. All my previous updates dome through usb. Only the very first 2 updates came through the OTA route.
Для моделей UB850-UB980, UC970 (webOS 1):
  • официальные онлайн-прошивки:
    для наших стран ->  от 05.2016 (на системе ashley)
    для Гонконга (HK) ->  от 04.2016 (на системе ashley)
    для Китая (CN) ->  от 10.2015 (на системе ashley)
    для Колумбии (CO), Тайваня (TW) ->  от 10.2015 (на системе ashley)
    для остальных ЮАР подобных стран ->  от 10.2015 (на системе ashley)
  • тестовые онлайн-прошивки:
    для России (RU) ->  от 10.2016 (на системе ashley)
    для остальных наших стран ->  от 06.2016 (на системе ashley)
    для Китая (CN), Гонконга (HK) ->  от 10.2016 (на системе ashley)
    для остальных ЮАР подобных стран ->  от 01.2016 (на системе ashley)
